Is this build really built for response, 8.5comp and no VCT sounds more like a big boost top end setup??
How would this build compare to a RB3025 neo with VCT and 9.5comp with even 50% E85 mix... surely that would of got big torque low down...
Yes I was trying to get response and from what I had, it is pretty good. It is very linear as it goes from idle to 6500rpm, well that was the highest I could go on the revs before it played up. But when I first came home I did get the chance to give it a launch from 5000rpm and there was a little 4W spin and no lag, so I guess you can say it has pretty good response.
To get near that before I was going from 7500+ rpm and it would still dig in a bit
Have no idea about your comparisons , I am sure there will be some blokes that could answer your question :)
Has to run on 98 and you have to stop spending somewhere
Everyone would love V-cam....but cant always afford it
Lol, how exactly does VCT help response over dialed static cams when response is all you are after
Yet still yet to see any proof VCT is better then properly dialled cams
The advantage of VCT is that you can dial in your cams for response at as low a revs as possible and then still get a good push further up when your static cams would lag behind. So VCT does not of itself create better response but it enables you to set up for maximum reponse while getting better power further up than if you did not have VCT.
QED
LOL
ROFL
ETC
QED
LOL
ROFL
ETC
So what your saying is VCT does not help response against cams dialled in for response :thumbsup:
Proven !!, really, where exactly is the proof, i read alot of people saying it's better but still no ACTUAL proof
Way to be selective in what you read.....
The whole point of VCT is that you can have the (int eh case of a RB25) intake cam set for max twist down low, then have it change over to carry the torque curve further up the rev range....
But Porsche, Ford, Merc, BMW etc etc must all be wrong......
Lol, kettle black mate
The point started at someone saying built for response but don't have VCT, i posted how does VCT better static cams dialed for response then Kiwi responded basicly confirming what is said
At no point did any one mention response AND topend :/
As the guys mentioned, i have posted my graph of my stock factory RB26 more then once for people to beat for both bottom end as well as top
And i'm still waiting
We are also only talking RB25 VCT V RB26, or any other cam timing setup that only changes the inlet cam timing from one maximum to the other, though would love to see how a RB with the VE cam setup would go
ooooo.....where?
Xkalaba, don't take it as a personal attack you have to defend!
I don't like your chances of getting a guy with stock turbos chucking vct on, so I don't think you will ever get the direct comparison you are after.
What's your idle like with the dialed cams?
Spends 8k+ on VCT kit but keeps stock turbos :rolleyes:
Idles like a babies bottom, smooooth as
Not like the 34, lol
Like i said, i'm happy to see a NEO with any turbo you like, so given the NEO has a "better designed combustion chamber" and NEO and the latest tech single turbo you can get it should easy walk over my 80s tech bush bearing factory twins on a static cam setup
I want to see same boost (19psi) run 290+rwkw and beat my 26 for response then prove it on the drag strip cause we all know dynos can be made to lie
I'm starting get personal about it cause every time i come on a performace thread someone throws up should have gone NEO or VCT and saying it with no proof is misinformation
ooooo.....where?
Fark it, cause one more time won't and you asked so nicely :P
This graph was done at a SAU dyno day back in 2007 4 days after the full wieght plus stereo R32 GTR ran back to back 11.3@125mph with a stock motor, the stock turbo world record in the link in my sig
  • Like 1
I should have bought your car from the get go, would have saved me a shit load of money and hassle , haha
  • Like 1
I need to learn more, but arnt the RB26 and the neo25 pretty similar heads ( apart from VCT) , if they arnt that much different then the VCT would of been good, in comparing response im thinking about how 34GeeTee's 2.5L graph with the HTA3076 has 280kw's at 4000rpm and that doesn't even have a stroker kit...
Edited by AngryRB
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
