I only run 15-16 daily/track and 19psi for dyno and drags, been doing it since 2002 and had replace a set cause bearing worn out and exhaust wheel was sitting on housing :D
Is that the SR VCT or VE ?
Doesn't the VE also do lift like the V-TEC
Had a remote tune this morning to see if they could get it a little leaner to stop the plugs fouling up and it seems to have more response in Boost off, low and higher boost levels. But still went tits up around 7000rpm.
But my question is, when I got my car back from the build the starter motor sounded like it was still engaged after I let the key go, screach! thought it was me at first , but not after that, after all the different cars I have started I should know when to let the key go :/
When I first told the builder about this they said maybe it should have had some lub on the shaft , then, it might be a mismatch with the new parts with the shaft ??
Now they said I need a new Hi Torque starter motor to go in, the old starter motor has no problem turning the motor over and starting the car, it just seems to stay engaged after it starts for a split second. I just want them to fix it as it was before the build?
Anyone had any experience with something like this ??????????
You wouldn't need a higher torque starter as the engine is now lower compression.
Not sure why they would have suggested that.
Lower compression, thought it was the same, maybe a little different with the lager capacity ?
Maybe because I suggested they did not install the starter motor properly after the build. It was OK before then ?
I love it when people say it was OK when we tried it , but the problems are there the first time you drive it out of the shop , farking black magic :merli:
Did you ring/email Jim to say that it still won't rev to 8000 RPM without it having a fit?
you cruel :( goes better to 6500rpm now and I challenge the whale for a quick run , TOMORROW! hehe
It is a minor hiccup that wont stop, hic hic hic hic hic , see what I mean, hic etc hic :)
Yes had a red , hic
Hi torque starter my arse, i have 9.5:1 static comp in my 3.0 with shorter duration cams then you and my stock starter starts it perfectly fine
mismatched parts is also BS, the flywheel starter ring should be exact to the original one and the starter motor gear will have a bit of wear giving more clearance then factory
It is most likely a sticky starter motor from sitting around for so long and should have been lubed before reassemble, but even then it was only 5 months, mine sat around for near 18 months and has never givin me an issue
  • Like 1
Hi Mick
This is what I mean, I might not know about modifying cars but I know if something is working OK and doing the job, you do not need to crank it up to do the same job, just fix it
https://youtu.be/ieVDfnUKN9s
this is what id expect from a big $$$$ build lol.. just throwing it up haha I know maybe totally irrelavent but hey the sound is enough to be ok with a bit less bottom end torque ...
start it up, run it and holy shit!!!
Edited by AngryRB
What Mick said.
Pete fwiw I wouldn't drive it other than to Sydney, you don't need it to foul up even worse when you're nearly there and in Sydney traffic.
he did a remote tune this morning and it is running much better, you can feel it, there is not much chance of making it worse,but?
Did you watch what he did to the tune?
Did he remove the password?
I am happy where my power is and it will only get better.
If you drove my car this morning and changed gears just before 7000rpm, you would have loved it, well I did :)
Once it is sorted it will be just what I wanted :)
Now that is some positive thinking,haha
Won't get worse, just considering the possibility of cumulative fouling. Probably not an issue at cruise but why take a chance when you might be spending a lot of time idling, stop start etc? Your call mate, just saying...
Damn that flutter!
look at the whole turbo to IC to intake plenum move from the 50psi!!
  • Like 1
Yeah, I know what you mean, but the idea of the remote tune was to tune it a bit more to the lean side to stop the fouling. and by the way it is running now I think he has done that, well I hope :)
He was happy with the result and has no trouble with me driving the car but I will not be doing much before it goes in for the retune
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
