I seriously don't know how they f**ked it up in the first place Pete..
For the money you paid that car should have had the time spent on it and be tuned to perfection
Obviously he did a half assed job and expected not to hear from you again, keep on his case until your happy mate. Some of these problems your having are foreseen problems, so I'm f**king sick of people trying to defend this shit.
"Just take it back and stay in their good books" blah blah blah,.. Should have been done right the first time! Idiots!
  • Like 2
I'm sure they have someone who reads this forum/thread so they are getting the picture that they are not setting a very good example.
Any who have you experimented with some higher octane fuel?
It is tuned only for 98 pump but as I said it is better from a remote tune than the Dyno job ???
I honestly hope they are thought they don't seem to be getting the message at the moment.
We re happy when it's reliable mate
I have other things that have to be fix before I go anywhere else.
I also have to give them a chance to rectify the problems.
Struggling with the Torque starter motor bit , my starter motor has no trouble turning and starting the motor, it just stays engaged for a split second after it starts the motor since the build, before that it was fine ?
The start motor is more then likely a case of shit happens and go get it fixed cause unless they swapped your starter with another one they can not f**k it
I agree they have done some things wrong but you can't blame them for everything either
I agree but swap shoes and see how philosophical you are then.
After paying to have job done , one expects it to be done properly by the experts and not to be given your car back worse than when it went in., the problems were all noticeable from the first trip home.
Things can be f**ked if you are not careful how you re install them and I am not saying this is the case, but you say to your customer, sorry mate your starter motor started playing up, do you want it fixed or a new one installed. You do not just leave it like that.
Yes shit happens and I am sure it will be fixed, but 7 months and still farking around with it, it just drains you, could be because I am an old fart and not as easy to get along with :yes::unsure::yes:
Just the way the car feels now I can feel it will be awesome when it is sorted :wub:
I see it from the mechanics side cause I use to be one, and as i said most of what is going on is bullshit and they should ashamed to hand out work like that, but blaming them for the starter is a bit much
Like the customers I use to have, change their oil and come back a week later saying I f**ked their wheel bearing
You have every right to complain for things that are obviously not right but just don't blame them for everything cause sometimes shit happens
OK, if you have something that works perfectly well and your car goes in for some work , they pull your part out and re install it and it comes back and it is stuffed, you just say shit happens,stick your hand in your pocket without question, I do not understand your logic ?
And I do know shit happens at times , some times it just does not stop , haha
Agree Brett, if the sm is legitimately buggered it's buggered and Pete would probably be fine paying for a replacement plus fitting. However in this case instead of just being genuinely concerned and providing an answer as simple as 'sorry to hear that, not good, let us look at it when you bring it in' they offer him a weirdass excuse and the opportunity to pay even more money (top $ for fitting no doubt) for a product he doesn't need.
(Edit: Pete's beaten me to it)
I'm aware of another situation where two bolts holding the ac comp bracket to the block were left out, so it wouldn't surprise me if they just didn't tighten the sm bolts.
Edited by Scooby
Take it to Jez and I can absolutely guarentee that you will be 100% happier how it drives
Jez would be well advised to stay out of this mess...until such time as CRD are finished doing whatever they are going to do or Peter decides to cut his losses with them.
It is unfortunate that some blokes knew my builder, I never mentioned them and wish it would have staid like that,but ?
Jez is not involved in this situation, some blokes have said he is an option for future work because I asked some time back for a shop that is closer to the mid North Coast, Gosford is about 1 1/4 Hrs easier both ways, he has never been contacted by me , I have not contacted anyone else, I have my builder..
The car is going back to the builder and I am sure they will do the right thing, by now they will be wishing me to the shit house, after the situation has been rectified I doubt if we will do any new business again, I am finished with modifying cars !
A full racing head might be the go, how about a different turbo, bigger brakes, seen a nice shinny radiator, hahaha
It is all good and will be worked out soon
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
