The setup you have if perfect ( except the exhaust, should be 3.5" min tip to tail ), it is just set up and tuned way off the mark
It is 3.5" exhaust, but it is on a 3" cat I think and stepped up to take the 3.5" exhaust
So I guess I need a bigger cat or ?
The dump and cat are the most important part of the exhaust as that is the first port of call for the exhaust gases
Should be 3.5 from the turbo right through
See if you can get that fixed before heading back to CRD
Venom 5" bodied 3.5" cat is best for flow
  • Like 1
Thanks for the info mate ,Paul was saying the 3" cat would cause a problem with the flow.
Here is a pic of the other side of the cat
That cat is really doing you no favours, changing that alone should give you a good gain, this is under the assumption the catylitic convertor is still intact
3.2ltr is alot of motor to flow through a 3" and while it will flow 400rwkw 3.5" will do it easier and with less backpressure, exhaust backpressure hurts turbo performance
he was talking about the back pressure and said I should have a 3.5" exhaust , I told him he had me put a 3.5" long before the build, then said maybe a 4" would be better?
I do not think they take any notice what they are doing or what they have done at times , I guess when you work on heaps of cars you forget, not hard to have a quick look to see what is holding up the flow and offer an alternative.what if the cat is not intact . If it is not , would it make any difference to change it ?
I will ask about the Venom and do something about it before I take it to Sydney if it is going to help..
I honestly think you need 4inch for the first half, and a 4 inch cat if its "high flow"..
If your keeping it legal then yea a 5" is the way to go
To put it in perspective, Paul has twin 3 inch exhausts on a 2.8
Once again CRD should know better
Trying to keep it legal, well as I can, I do not know where I want to stop with the mods :/
Why would 5" be better, do you mean run a complete exhaust system, just spent $2500 on the one I have, haha
4" system with 5" cat.
In the photo it looks like they necked the exhaust to accomodate the small cat.
So in anticipation of the build they tell you to fork out 2600 beer tokens for a 3.5" exhaust and now they tell you a 4" might be better? Alternatively, they built an engine package and tuned it all at your considerable cost, and immediately after tell you the exhaust is too small? Maybe I missed something.
3.5" will be fine for your goal, though a 4" would be better
I have twin 3" into single 4" on my 3.0
Like i said i would change from the turbo to the stepup in 3.5" with a 5" bodied 3.5" cat and be done with it and that will help the turbo response by allowing the gas to get out of the turbo easier
No Mate , the exhaust was done before I made my mind up to do the build.
But as you can see they did step the exhaust down to fit the cat?
I am not sure if the cat has its internals ??
If I do something with the exhaust I will make sure it is done properly. I will get as much info as I can before anything is done.
Where do you stop? Exhaust has nothing to do with an engine build. It has everything to do with performance, but if it's not on the list of things to do where does one stop?
Can't expect them to do all the recommendations. Engine build isn't a car build.
I thought I was finished with it, haha
Thought the exhaust was OK, I did not just do the motor, did a job on the drive train, C Spec coppermix twin clutch , Quaif front diff, modified the trannie and have a Nismo 2-way LSD on the back and that all works a treat , add the AD08Rs and all good :)
Well CRD is a pertormance shop and should know enough to know to atleast recommend enlarging the 3" section to 3.5" while car was getting upgraded
I think this was another problem, there was no guidance as to what the car needs, to make the bolt ons I chose work better, maybe I would have said NO, but at least put it out there ??
I will ask them what I should do with the exhaust, then I guess I will have to try and sell the old new one :(
Everything seems easier in 20/20 :)
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
