I would not bother staying in Sydney if I were you. I'd drop the car off and go home. Then call them routinely and get updates.
Get a friend to drive with you and drive back
Doubt very much that I would be staying in Sydney.
I would not ask anyone to drive 8 hours so I can drop my car off, I just could not do that . Apart from the kids I am a bit of a loner, always have been :)
Got a date for retune yet Pete?
Not yet mate, they were tied up for a couple of weeks so maybe a couple of weeks or so, I do not want to give it to them unless they can start on it immediately, well hopefully, well maybe, well it could happen , haha
Sorry if its been covered earlier but is this the initial run in tune on a new motor? If so your tuner isn't going to push the tune hard straight up normally its very conservative in regards to timing ect. Just a few degrees extra will make a big gains in output.
Hi Ryan, not sure what graph you saw, this is the final tune
Have to take the car back in a week or so, there are a few ongoing problems to sort out and after that I have to think seriously about what I will do.
I think if I really want the car to run as it could with the build I need to dig into the pocket again :(
I might get the Dump and Cat changed and fuel situation sorted so it can handle it if I turn it up a bit. The exhaust is getting back pressure and the fuel is close to the max, so I an thinking of getting another Walbro 460 and running both into a surge tank, new lines and twin fuel rail. If I decide to do these mods, then I will then get the flex fuel tune done. I did not think it was worth doing the Flex Tune the way it is, it would struggle to take advantage of E85
Also thinking about getting CAI box done, the END :) AGAIN :)
I think he means twin entry rail.
You can get a good rail for $150 that will suit ID 1000/2000s
The real cost is in the lines and fittings,
You also don't need a massive fuel pump feeding the surge tank, as thats where fuel is returned too
and you definably don't need 2 feeding it.
I have a nismo lift pump and 2x walbro 400s in the surge tank feeding the rail
Even that is over kill in some people's opinion
Hi Joe
I will have to ask some more about all of this and there is plenty of time to work it out..
Yes, I think twin entry rail, I do not know the difference, I need to ask more questions and then have to look it all up :/
If I do this work naturally it will all be done before re tuning the the car for 98 and E85.
I have a near new Bosch 044, can that be used as a lift pump to the 460 Walbro in the tank to feed the rail. Are you saying that the standard fuel line is adequate on this build ??
I see blokes doing all sorts of mods on the fuel line and do not have the build I have, understand, I was not going to touch the car again and here I am, it is worse than f**king drugs :(
Still can't believe your running a 3 inch restriction in your exhaust. If that was on your original engine before, it could explain why it was so laggy. Hope you sort it out. Sounds as though it will be nice to drive.
They said I needed a 3.5 inch exhaust done with the previous work before the 3.2 build.. Then I checked the Dump and Cat after the build and they are 3 inch. I am going to a 4" Dump and maybe a 5" Venom Cat and see how that goes with the 3.5" back from the Cat. If there is a problem with that it will be changed.
I will go ahead with the fuel mods and the Flex Tune at some stage, I would rather overkill than pushing it . But I will wait until after it comes back from the repairs and see how it is running, maybe I will do nothing if I am happy with it???
I wouldn't bother with flex until they can completely get the 98 tune sorted . imagine the ecu scaling between 2 tunes, you're having enough problem with one tune.
Yeah Ben, it will be done before I do anything else, it will be interesting to see how it is going when it comes back
The excuse was that "it was setup for a 2.6L".
Out of interest Pete, what/who made you go for the 3.2L stroker in the first place? Given the expense it seems like a curious mod path (to me) given what you wanted from the motor and given you had no prior experience with RB motors!
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
