Woudn't need an AVO to keep me away from you in fishnets.
you know how to hurt a girl :P
With the cold weather the car does not like to start, well it starts and you have to keep on it for a minute or it will konk out.
warm, no probs. But over took a slow bloke in the 100 zone in 5th and with load and the motor just died/stopped for a split second as you accelerate , drop off and it kick off again. Revs OK in lower gears up to 6000 rpm ish
Busting to have it sorted :(
Do some work Paul :)
What a joke.
If you portray yourself as someone with no knowledge then it seems you get taken advantage of. As per this case.
Not a very good look from a workshop that is/was reputable on here.
Yeah , I have been pissing myself laughing for a few months now, when will it stop , my tummy hurts from laughing :)
I had NO knowledge at all about modifying a car. That is why I used a shop with a pretty good reputation.
But I do not consider myself totally stupid, 2 jobs before were fine,price as quoted and on time.
I put it down to shit happens and it can be fixed, so no probs in the long run :)
What a joke.
You say what a joke,
But it's been the same issue from day dot. No matter how many posts or examples have been given over multiple weeks, its still the one issue, not multiple new problems arising.
Yes you are right, probably my fault bringing it up, but it is difficult when blokes ask what is happening not to vent a little frustration. I think it all goes back from day one and the way the job was handled from the getgo and then it all went tits up after the build was completed.
But it goes in next Monday , so it will be interesting to see how it comes back, these blokes are good mechanics and I believe they will sort it out .
Back to, shit happens :)
Jangles, do you have your build specs anywhere on SAU ?
Nah I've never done one
only because there used to be a zero tolerance on slander
I have no control over what someone else writes . That would mean anyone can go on a thread, crap on some company and the thread gets closed. Edit the post, not close a thread.
I mention what is wrong with my car, but always say I have no problem with my "builder" ( no name) , I say shit happens and they will be fixing the problems,
I never mention anyone's name and purposely do not put shit my on anyone but I can be unhappy about my situation , it is farking frustrating when you spend a shit load of $s and it is not right to drive after 8 months..
Goes in next week and hopefully that will be the end of this, well except I will be finishing the build at some stage and like to post the results
tell them it should be as good as this one, lol https://youtu.be/vfa7dn-N4F4
should do as good as a dirty VL :ph34r:
Yeah , hate to be sitting in the boot if it broke away :)
Someone could do that with my motor now, well after the dump/cat and fuel is upgraded, change the Turbo, cams and a new tune and it would be pretty strong, but maybe not where I want it "/
Off topic here.....so the car goes in next week?
How long will it be in for? I would be looking to get costs back on travel or push for something.
400+ KW on 98 or give it back :P
Yeah Brent/ Joey, next Monday and looking forward to get it back in A1 condition.
400+ I doubt it. I am not getting the new work done yet, I just want the problems fixed ASAP and move on.
As to when when it will be finished, guess it depends if they start straight away or not and if they are willing to give it the attention the job deserves. They should be able to have it done within a week or they are not trying , so time will tell :)
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
