Educated Guess At The Final Tune Results
Yeah i agree i just had a good dump! Feel so much lighter! :D
Great news on the car Pete i think thats the least they coulda done being the high end customer you were! Your build wasn't exactly a budget build so why they left pieces of the puzzle out like dump pipes etc before the tuning process was beyond me?!
haha, you bad :)
Probably going 4" would be better but at least it will be 3.5" all the way should eliminate a bit of the back pressure he had when tuning it. It was an offer I could not refuse and I appreciated it :thumbsup:
Looking alot better.
Yeah exhaust is key - gotta get rid of the hot gas somehow.
I was going to go with the 4" dump and cat, but could not knock this offer back.
I did not mind having the 3.5" exhaust system back from the Cat as it was built to flow and once the gases got to the exhaust it would be cooling a little.
Soon find out how the 3.5" goes, maybe a week before it's done ?
You'll be fine with 3.5 all the way.
Will be excellent.
Thanks, do you really think that 1/2 an inch will make that much difference, there is a step down from the turbo to the dump and a step up from the cat to the exhaust. I guess it would have to be restrictive.
I have heard said that an 1" makes all the difference but never knew what they were talking about :)
Some rough calcs
Area of a 3 inch is 28.2 in 2
Area of a 3.5 inch is 38.4 in 2
Area of a 4 inch is 50.2 in 2
From 3 to 3.5 is 36% larger.
Some rough calcs
when it is put that way it is pretty impressive ?
what does 38.4 in "2" mean
He only got a rebuilt bottom end and some diffs put in, would hardly call it high end.
Not to take anything away from a 3.2 stroker of course
haha, a little bit more work than that, but not finished yet :)
Of course there is a lot holding this together but without nuts and bolts.
Nitto 3.2./ RB30
PT6262 CEA
9Lt sump conversion
supertech 1mm OS valves and stuff
head cleaned up
custom UE 260 10.8 cams etc
Koyorad radiator
Splitfire coils
ID 1300 injectors
Custom catch tank
Haltech ECU Platinum Pro R34GTR
Flex fuel sensor
HKS EVC 6 Boost Controller
3.5" dump,cat and custom high flow stainless exhaust ( 3.5" cat and dump now going in the car)
Nismo slave cylinder
coppermix twin C Spec
Quaife front diff
Modified Transfer case
Nismo 2-way LSD
Next to do after I get over this lot is,
CAI pod cover
Twin Walbro intank surge tank and fuel lines etc
Full Flex tune.
I know there are shit loads more you can do to your car to call it a top end build, but for a DD it is a pretty strong build that you can drive to church or get you to heaven, real quick, or HELL :/
Nitto 3.2./ RB30
PT6262 CEA
9Lt sump conversion
head cleaned up
Koyorad radiator
Splitfire coils
ID 1300 injectors
Custom catch tank
Flex fuel sensor
Quaife front diff
Nismo 2-way LSD
CAI pod cover
Full Flex tune.
I thought the turbo setup and fuel system was already on it for some reason!
The Turbo was on. Left a lot of boltons on the car and have been upgrading them as needed.
I had no idea when I started this I would go to this stage :ban:
They told me the fuel delivery was starting to be a problem, especially if I go for E85 and wanted to turn the wick up. Then, the surge tank would be a good idea. I am sick of worrying once I get down to 1/4 tank if I am playing.
Going to end up with a jumble sale of parts soon and all of them are near new :)
I would say a surge tank is a necessity even on a tuned 26 with good rubber. All it takes is one fuel starvation event and your engine is gone. Not worth the risk to be honest.
That will be getting done very soon, just have to get this sorted , then get the parts and book it in :)
Rubber is pretty good, 265/35 x 18 AD08Rs , they really grip!
LOL @ this guy! Are you serious mate? I don't know what Petes bill was BUT it'd have to be starting at $30K+ im pretty sure thats enough to be classed as a high end customer!
Sure there is blokes/GTRKAT that throw bucket loads more money at those blokes than Pete did does that mean he deserved a car that wasn't setup right from the beginning does it?
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
