Take it to a new tuner, drop the car and see how much more power it makes.
I would NOT be surprised if the figures are fudged to make them seem similar to previous result, therefore making CRD appear not as stupid
  • Like 1
Pete, I find it hard to believe that the bigger duration cams mad as much response as the smaller cams.
Also find it hard to believe that the larger exhaust didn't make a difference.. Unless the Cat is now restrictive. What size was is the cat?
Also can you post these "diary" results Pete?
Power seems low. With my 2.6, I had 422kw @20 psi on 98 with the smallest t51r. Yes I understand that it's not the same turbo but I don't think yours would be 40kw atw lower given a bigger bottom end
Also it took them that long to do all that? Did they list specific days and how long they worked on it?
Apparently the cams are a restriction
Yes , as every one knows Paul, your hideous White Whale choked with these cams , no bottom, middle or top end , no wonder you are pissing it off , oh, I have a forged 26 bottom end for sale , I know how you love them :whistling:
Might put the Poncams B back in :/
Might use the other cams for road base
Totally different turbo.
Fatz just went 399 at 22 psi with the same turbo on a 2.6 on E85.
Pete went 386 on petrol at 22 psi.
Guys seem to see STROKER and expect 92736262718126 kW.
Give it a gut full of E85 and wind this thing up. It won't win dyno comps, never will but to drive it on twisty roads, no hunk of shit, gutless, twistless 2.6L "revvy" *rollseyes* GTR wil catch it on the same setup.
For the restrictions that it's got/had with the 3 inch dump pipe, I'm not sure what people are expecting. 450 kW on petrol, you're dreaming!!!!
  • Like 1
Give it a gut full of E85 and wind this thing up. It won't win dyno comps, never will but to drive it on twisty roads, no hunk of shit, gutless, twistless won't catch it on the same setup.
For the restrictions that it's got/had with the 3 inch dump pipe, I'm not sure what people are expecting. 450 kW in petrol, you're dreaming!!!!
Oh, your so cute when you are mad :wub:
Are you crushing cans tonight :cheers:
And as for noisy top end with these cams but quieter with the drop ins. I have the same cams, springs and retainers. My top end noise is no louder than any other GTR with say a set of poocams. Are the clearances set correctly?
  • Like 2
Doesn't sound that bad Pete. The new dump will improve response, something you should really feel driving it rather than see on a dyno. Obviously the turbo was selected for response so that's why its running out of puff up top on a 3.2 and why the bigger dump isnt making much difference in the top end. Don't stress about it. As long as all the tuning is done right so you don't have the previous issues. Don't worry about e85 either, it would be a head f**k for a daily seeing that its becoming more scarce. See how you go but I recon it should be exactly what you want. Hope so anyway. :)
  • Like 1
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
