Educated Guess At The Final Tune Results
Doesn't sound that bad Pete. The new dump will improve response, something you should really feel driving it rather than see on a dyno. Obviously the turbo was selected for response so that's why its running out of puff up top on a 3.2 and why the bigger dump isnt making much difference in the top end. Don't stress about it. As long as all the tuning is done right so you don't have the previous issues. Don't worry about e85 either, it would be a head f**k for a daily seeing that its becoming more scarce. See how you go but I recon it should be exactly what you want. Hope so anyway. :)
I am not sure how it works but the PT6262 CEA is rated at over 700HP and this is only running around 520HP @ 22psi so I do not think it is running out of puff, might need some boost to get the 6262 going harder , do I need more boost, I do not think so,but it would be interesting to see how it goes :)
But as you said, it will be all I want if the dump gives a little more response and it only matters when you are driving it.
Why didn't that embed......
What's the response of car like, or not driving it yet?
Not yet, should be sometime this week, if the leak has been sorted, should know tomorrow and maybe it will be tuned then ?
Based on others, 6266 is better for higher revs on a 3.2. Your 62 rear is probably restricting exhaust gas flow. Even if you increase boost its a scenario of diminishing returns comparing to a bigger turbo, but the trade off would be low end. But the 3.2 will look after that to a point.
  • Like 1
Your probably around the 560-570hp mark ATM Pete
700 is absolute best case scenario
ATM it is about ,615HP ish crank. well I think 386 awkw is around 520whp
I know I keep saying this, but I still want it to go earlier , so I will wait and see what happens when I give it a run :)
I'm probably missing something;
Ran car at full power (identical set up?) and noticed less power than before...casual observation, nothing more to add?
Turned boost down (from 22 psi) and then it doesn't misfire...is that being offered as the solution to the misfire?
Put other cams in that were found to be better, then took them out again...?
  • Like 2
I know this will sound dumb to you blokes that have driven these cars for yonks, but getting used of a car that revs so high is very strange.
This car was limited at 10000rpm, or maybe no limiter,the first time I went over 10000rpm because I was too slow to change up, it went nuts from 6000rpm , hit 10,000 in a flash and I shit myself LOL
Lets see how it goes, only a few days to wait until I get my arse in the car, that is the only test :)
All jokes aside, what's the obsession with turning them so damn hard? Is it the noise of it screaming it's head off?
Mainly because it would not go over 6500rpm, there was no need to do it. Shit load of fun @5500rpm :)
Not talking about your setup. I'm talking about turning the to 10,000 rpm and beyond for a car that's driven on the street. Is 8000 rpm not enough?
All of the above. He he. Love it.
Seeing you're such a fan of 26s, I think you will like to know I am putting a t04z on mine shortly. More lag, just the way you like it, he he
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
