With all the decent stuff out today, you put something on from when T. Rex's were around. I just don't understand? Not having a go at all, each to their own...but really? lol
If you want "all the lag", why not just use 1/3rd throttle to 6000 rpm then plant your foot. Atleast then if you have to move quickly you have the choice.
  • Like 1
Someone called?
Rawr
  • Like 1
I like waiting.
I'm in a similar boat.
Going back to big low mounts.
Hard to get new tech in direct bolt on.
No longer want a single.
And stuffing around with gtx cores and cost didn't appeal to me either.
  • Like 1
Not talking about your setup. I'm talking about turning the to 10,000 rpm and beyond for a car that's driven on the street. Is 8000 rpm not enough?
8000 was not enough when it did not get started until 6000rpm with the T78-33D :(
I'm used to waiting.
Between rebuilds.
Ha ha ha ha ha ha.
You're not doing it right Luke, Paul has the right idea, overlap the builds and cut one out , you do not even have to waste your time driving it,LOL
The box will arrive this week. Should it put it in to make you happy? Haha
That's cause you obviously don't like fast gtrs
Whats the good of your car starting to go fast at 6000rpm as a DD, after I picked it up from the first final tune after I bought it , I wanted to sell the heap of shit on the way home.
So if you want a little spirited driving as a DD and you have to wind it up to 7000rpm and let it go to beat a Tiida, you can have your fast cars mate.
I know they would be good on the track once you have your revs up you can keep them there or drop a gear or 3, try driving like this on the road, give me a farken break.
Apart from the obvious problems, the car is "plenty fast" and I do not have to thrash the shit out of the motor to get it there, so all good :)
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
