Have seen that before.. Leaks under hard throttle only
I came in after a few different runs and let it idle, seen nothing. Turned it off and watched for a while, nothing. Backed out of the garage, nothing on the ground, it was a hard farker to find :/
From what was said there was no noticeable power gains with the addition of the larger dump pipe, said he took the exhaust off and there was some good gain. Very disappointing at this stage but as long as it is going hard to 7500-8000rpm without farting and I do not have to top up every day, all good :yes:
Good power to 7500.
So what if it doesnt make peak hp after this.
Get it back and drive it and make sure there are no more gremlins.
Enjoy the response because that is how it was setup.
Dont worry about dyno queen figures......... just drive the f#$kin thing.
Good power to 7500.
haha, I know what you mean. This thing was still fun when it would only go to 6000rpm , all good.
I only know how I want it to feel, Dyno is a window to see how it gets to the 7500rpm :)
They said there was no noticeable gains on the dyno with the bigger dump and cat, but maybe the response has picked a little up with the extra size and not noticeable on the Dyno ?
Edited by Nismo 3.2ish
I am sure the car will be OK, it s not in there interest to give it back to me stuffed again, shit happens but that would be stupid :/
If it is stuffed I will have another mechanic look at it !
Skids. Limiter bashing. You have to check the rev limiter.
Will do mate, I have just the private road to test it on, shake the limiter, not sure about the skids, this sucker holds the road tight on all 4 :)
If they have fixed the problems and all is good, even near good is good enough, I do not want to go to Sydney anymore for work on my car, I will find someone closer for any smaller type jobs.
I will never need another build, I am done with it and this car meets all my boyish needs, love the look, its history, goes quick in a straight line. great on the twisty shit and I love driving it , farking heaven :worship:
  • Like 1
It has grip????? What is that like?
My R32 gets its drift on easy :)
Need a controller.
haha, I am the controller :)
Your 32 sounds like fun, years ago I would have been there with you.
But I like the feel of it holding the road and wondering when it will let go, thats enough excitement for me, to each his own.
Just a few hours to go before I get an idea if it is going any better, fingers X
Then just a couple of touch ups an in a few weeks, all done :)
Whoooops said that before :/
  • Like 1
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
