Educated Guess At The Final Tune Results
haha, thanks
Hope I do not get too bored too soon, well the builder should get bored before me, he had it longer :)
When you get bored just put a bigger turbo on it. Response gets boring quickly.
I will look out for your next thread, titled ' I love my car BUT its missing something' ha ha
I think you should relocate that number plate just quietly.
And I hope you don't have another misfire. That would be beyond a joke
I like it there, no obstruction for the air and you do not have to bend it at each end to go into the original position , a lot of Plates look like they have been nailed on, see great looking Rs and shitty plate positions and conditions ?
Not worried if it is missing again, I am not going back to Sydney and I am sure I will find someone closer and go from there.
Shit mate if everything worked the thread would closed and my life as I know it is over :(
Just watch this spot mate, I might have to steal your name for the thread :)
I never got sick of a car with response and have been loving response for over 55 years, but it took about 2 klm to hate lag and want to sell the car.
Big turbos are exciting and I am sure my car would be great with a big modern turbo, that is, if I could ever use it :/
Each to his own mate, just got to love cars and driving them :cheers:
Old wives tale........ You can always use it..... He he ....... Always. :D
haha, but getting it up to 7k and dropping it at the lights or out of Woolies car park is not a good look, fun no doubt but is frowned upon by the boys in blue :)
Where is the RPM on that Graph?
Is it 300kw just under 4000rpm?
Max torque is extremely early - beauty of 3.2L ay.
I want to compare my graph - same power just .6 of a L down.
Edited by Stixbnr32
Mmmmmm, some falsely say it is the case. Never had to do it myself. I think people talk a lot of shit really, or just don't know how to drive.
The next tune I have done will have RPM and you will bet a comparison , I find these Dynos without the rpm to be a pain. I will try and have the few things I need done ASAP and it should be interesting to see if they can do more with the tune and cam dialing ?
Is there anyone reading this that can put the revs to the KPH.
Paul was saying that I have lost 5.2KW but at 18.5psi not 22psi on the last tune , as you can see the psi drops off from 24psi @ 351kw and makes full power @ 18.5psi of 381.7KW, so I guess it really did not loose anything with the new dump ??
Stuffed if I know how it works :/
Looks like your making the same power with less boost. That's a result of a better dump (good thing)!
Also what Hadouken is saying may also be true, the spark could be blowing out which is why there is now less boost.
If this is the case there's an easy solution to this problem.. It's just more $$$
You might be right about the driver , me :)
I had a T78 so not a new age turbo but it was hideous as a DD , but I guess we all have our own idea of lag for a STREET CAR, " not track or hill climb." as I know shit all about this type of driving, but I know once the revs are up they are great.
Turbo is too small. Turbine housing too small which restricts flow and chokes the engine. In this scenario you have no choice but to cut boost.
It will be interesting to see what an e85 tune does because if it makes no significant difference then the turbo selection is the problem.
  • Like 1
New coil pack ?
Interesting that the boost tapers of so much, would be alot better if it could hold.
What wastegate and what boost controller peter?
He said he cut the boost , but I do not understand that as the last tune was 22psi and this was at 24psi to kick off and dropped off to 18.5 psi?
I put the PT6262 CEA Turbo on it as a 2.6l, left it there to see how it goes.
Personally I do not care what E85 does , I cannot buy it here, just like having the option and would love to feel the difference from pump .
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
