I haven't yet needed/been able to to rev mine past 7000, maybe I'm driving too soft Pete!
Would be interesting, but I doubt it can flow much more air than it currently does at that rpm on a big capacity, hence why dump mod didn't change much?
I use do take MI e to 8.5 or 9k.
whichever the limiter was set at.
went good.
went good.
Before the build I could hit 10k with not trouble, because I was too slow to grab 2nd the first time I booted it :)
Even when the T78 was changed for the 6262 it was limited at 9.5k and no trouble getting there. I could never stop myself from testing it :/
Maybe there is also some cam adjustment for a bit more grunt as I do not need anymore than 7000rpm.
Can dialing the cams make much difference for response, there might be something left with a bit of tweaking ??
Still not responsive enough?
Shouldve gotten a M3 or C63 AMG with this amount of money.
Limiter a day keeps the doctor away. Gotta make sure its still there
I did not want another car, I like this one!
Dead a long time Mate , might as well do one really stupid thing in your life :)
That's why they limit them, so you can check it out when needed .
Should have got RIPS NZ to build you a 3.2L would still rev to 9000rpm :P
shoulda coulda woulda, but I didn't and what would I do with 9k , thats why I went this way. I did speak to them earlier but I still needed someone to pull it down and put it together and fix it if shit happens
No mate it will all be good, nice looking R that holds the road and goes pretty quick, early :yes: :yes: :yes: :yes: :yes: :yes:
Why?
The bottom end hasn't flung apart. The only possible reasons for the rpm limit are turbo restriction, or ignition issues, or potentially the cam settings.
All a bottom end has to do is stay in one piece, everything else actually makes the power.
  • Like 2
If I wanted big power I would have gone bigger bolt ons.
After I do the fuel mods and flex tune I can bump it up if I ever wanted without costing and arm and leg, because I have already spent the arm and leg :whistling:
We aren't saying you did want big power. We are saying that the other guy is off point by suggesting another builder would have it rev to 9k with the same parts
  • Like 1
I understood what you said and even the 2.6 that CRD built that was in my car , was strong and rev it's head off, or your head off.
I believe the 3.2 motor they built me is as good as most.
It seems more blokes want the top end bigger power and I understand why, it is exciting when it kicks in and when you have the revs up.
I thought about doing some Hill climb events once the car was 100% and watched some more hill climb vids this morning, that was the end of that idea, they take it pretty serious and rip! Do they have any geriatric events or do they have a different class for the mug drivers ??
Ummmm not necessarily.
Why not, I guess it is what you think is expensive, poke in a new suitable turbo and maybe different cams dial them in and tune , E85 and away you go. I wish :)
I am not talking a 900 HP car but it should be pretty good
I have better expectations for mine as it is set up now and if it does not meet them I will change whatever.
To get it going set it for 2000rpm. There's your response.
SET WHAT ?, I take it you are joking and pulling my leg ?
If not, Do a Pauline, please explain :/
You know that I know nothing much about modifying cars, only what I have been learning while on SAU. I know more now in 18 months than I ever knew about cars and that is not a lot.
Up until now, I just buy them, drive them, brakes down someone fixes them, it was easy, only had to have the NRMA card with you :)
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
