SET WHAT ?, I take it you are joking and pulling my leg ?
If not, Do a Pauline, please explain :/
You know that I know nothing much about modifying cars, only what I have been learning while on SAU. I know more now in 18 months than I ever knew about cars and that is not a lot.
Up until now, I just buy them, drive them, brakes down someone fixes them, it was easy, only had to have the NRMA card with you :)
Sorry Pete, I'm referring to the nitrous setup you should have on the car. Not some other random setting!
See what I mean Ben, I know nothing :)
Get the same kick out of baked beens :/
  • Like 1
haha i was kidding about getting RIPS to build the engine...although they do a wicked job.
200hp shot of NOS. YES!
I think that 900NM is going to be a handful anyway.
I was seriously thinking of using RIPS and he was very helpful but as it turns out Sydney was too far :(
Have seen some of the motors CRD have done and they can be very strong.I think he specializes more in the upper range HP , but ?
Have a look on Piglets rebuild, there is a vid of Steve Ka's time attack runs at WTAC 2014, that would get the blood pumping to your low head, haha
If you didn't know but Jhh racing in Qld build great motors as well, just saying...
The motor is fine Ali, just a few touch ups and away we go.
You can see the boost drops off from 24psi @ 150kph to 18.5psi @ 250kph ish, at the 381.7kw mark, there is something wrong with this and it will be checked out and fixed.
I also think there is more to get down low from a different type tune :)
Going off the Dyno Graph, what do you think the KW would have been if it held the 24psi until the 7000rpm.
I maybe wrong and I'm no expert but I think you maybe at your limits of pump fuel, hopefully the e85 tune will give you what your chasing.
CRD build tuff cars and I've witnessed it in person last week. But I feel CRD did that tune for a reason, maybe ask the tuner the question?
Also what is your engine compression ratio?
sounds like your power hungry
You can still get a c63. Oh oh, saw a M6 today. That shit was hot, and sounds so good
If you are practicing to be a DH, you can stop, the Dux you are :yes: :yes: :yes: :yes: :yes: :yes: :yes: :yes: :yes:
I might be 100% wrong but I believe it should be better than it is.
So you think the boost should start tapering off at 5000 ish rpm with the mods I have ??
You may be right about the pump fuel, but that does not mean it cannot be better down low, it is not much better than when it was a 2.6 apart from the torque until the turbo kicks in
I have always said that CRD builds tough motors and gets some big HP going.
I asked the question to them 4 days ago why the boost tapers off , I got nothing ?
Anyway, I will have it checked out and we will see what the problem is and fix it very soon. Maybe it will go better , maybe it won't ?????
But it is still fun to drive :)
Gets a massive single and complains about lagg...
Doinitwrong.
Just quietly my poor man's 2.6 made 320kw on pump with -7s..... Soon to be more with e85. Any man's guess as to what it will make... Guessing 350. Maybe more. I'd say the -7s will run out of puff at 350.
For people to say you need e85 for it to work properly should be shot. Unless it's a track build the idea of e85 is great but it's availability makes it mediocre at best. keep in mind I'm only flex tuning it because haltech and it was $200 more than setup on just 98. I will be running 98 most of the time.
If you are not happy with it now, pull the turbo off and go smaller and run less power. E85 will only bandaid the issue and not fix it.
  • Like 1
I just had a look at both of your dyno runs, old and new. If piggaz calculations are right they only revved it to about 7250rpm...
Interesting if that's correct? Once again I could be wrong I'm not good at maths
The 3.2l is no miracle worker.
You won't get n/a response doesn't matter what you do. You can't get linear torque nor power with an low compression rb at the power you want. It just won't happen.
As I have said previously your turbine is to small to make any significant power in excess of what you have now. To tell you the truth I recon CRD did a pretty good job trying to tune that turbo on your setup it must have been a nightmare.
In a nutshell, you either need to decide on higher power or better response, you can't have both.
People have been telling you this all along.
  • Like 2
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
