V8's are overrated, Just set that RB up properly, look at the results with FP turbo's, an FP35 combo would give you what you want both response and top end with right housing, just look at 34GeeTee's results with only a FP3076 on an RB25, he got 390kw's with big mid range, with a 3.2L and FP35 it could be a perfect match...
The only way I will know is when the next work is done and there are results to compare, main test is driving it.
The Skyline is something that gets into your blood , why, farked if I really know ???????????
Had a look at the FP3582 and 3586 if these are the right 35 models @ 75Lb/min as to the PT6262 @ 74Lb/min.
What is the main difference with the FP and PT Turbos , they seem similar?
Who knows :P
I reckon enjoy the car for a bit, no more thinking about mods!! Then get the car looked at by DVS or whoever and go from there.
I do enjoy it, but it is not finished and I was always going to do the surge tank and pod cover, just adding the flex tune , well not adding it, I thought it was getting done with the build :)
ok - I want to see a vid of this launching. Did they setup launch control?
Good point, I think the Haltech Plat/Pro has that function, has to be better than some of my efforts, haha
When it is done I will do a Vid of a launch, have to give you blokes a laugh after all of this crap :)
Would it really need it? being a street car and such a responsive setup
I do not think it matters if a car is responsive or not to have launch control, they have it on the GT-Rs and they are very responsive.
I see it is easy enough for a mechanic to set it up, so maybe :)
Does it stay active all the time or is there a button/switch to activate it?
Its not hard to launch a gtr
Just get the revs up you want, I get the feel the clutch is engaging, let go and away you go :)
Thought it might be interesting to see the difference ?
The key is to use the handbrake and clutch to pre load the drivetrain so you dont "shock" it upon take off
Thats what I said I do, I feel the clutch engaging before I take off.
Listened to blokes saying take it to 7000rpm and step off, no thanks! I will make it as easy as I can on the driveline :)
I take it to 7krpm sometimes more depending how sticky the bitumen is
This was when I first bought the car, if I did not do 7k it went nowhere.
I do around 5k now and that seems pretty good, I also have AD08Rs on and they are pretty soft
haha what they did setup launch control - It sits there in your power band and lets your boost build and then load it up and release.
That is why new GTR's have it as well as all super cars.
That because they are basically autos, you know, so the launch doesn't rely on driver skill. He he.
Would rather have a skyline auto, big stall with a trans-brake. :D
He already knows the answer. He is just ignoring it. An engine is just an air pump. His results are on par with a majority of other results using the same turbo on 3l+ capacity but somehow he believes it should be different. Maybe some fairy dust and a happy dyno is what he needs.
Have u had a car with a restricted turbine that caused boost to drop as peters did?
No issues with mine holding boost with a similar size turbine wheel.
  • Like 2
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
