You have 2 answers thus far for you boost tapering off.
1) Turbo is to small for the 3.2L
2) You are running out of spark
Im going for 2
#2 . Paul said that before I posted these results..
Do you think the turbo is really too small if I do not care about top end, I thought it would shit it in to go 550HP ish with the cams dialed in for response.
It looks like the intake cam may be retarded , that is if I understood what was said to me :/ maybe I will find out tomorrow.
The trouble is, some blokes think I am after more KWs, I only talk about it as a reference point because most do. Since I posted the first tune , most expected more KWs ( I guess I did as well but I am a beginner :) but I did expect it to get going earlier .
Before someone tells me buy a different car! I love my R and love driving it, just want more of what I got. I probably do more Klms than most and truly get my monies worth :)
What I find funny on forums, if you are chasing HP far beyond your mods , it is OK and blokes say just keep trying. But go for response , your a dick head for wanting it and go buy a V8. well I will go for the DH of the year award and loving it, haha
Hmmm...
I bet you have great response looking at the results, but I think you mentioned a day or so ago that you wanted more response....
That is where I think you are starting to be unrealistic and you are wanting something that this car/setup cannot give you. This is why I said you should get a v8.
I think they've done as good as they can with 98, if you ran some E85 I think you'd get what your looking for.. you'd have 40 or more killawasps more from 4000rpm and a more lively bottom end, probably 450kw's at top end and be happy... just have to buy some E85 once a month..
  • Like 1
Im going for 2
My bets are on 1.
Or maybe 2 because of 1.
No one is calling you a DH Pete. You are asking questions and people are giving you answers. In a perfect world everyone would want maximum response and maximum power, in the real world the choice is always a compromise.
I am calling myself a DH too, there are too many blokes that know these cars that say that I have got as much as you can out of it and it is probably true.
Maybe I just watched too many Vids of 1/4s, hill climbs,track and never took any notice how these cars get going, revs !
It is still the best car I have owned to drive :)
Top setting was 22psi before this tune. But running on 22psi it went tits up at around 6000rpm.
Now it went to 24psi @ 4500rpm before it tapered off to 18.5 @ 7000 ( I think the 381.7 kw was around 7k , the private road I used would not let me go to 7k in 5th gear, just squeezed in 4500rpm, too short) Not sure if it is actually set at 24psi, just going off what I can see on the dyno chart before it dropped off.
There is no harm in having a guess at what is going on here and in about a month there might be some answers, could be better, or worse ??????
My boost tapers off on paper too.
My speed doesn't when I'm driving.
CRD time attack bnr34 supporting a stroker 2.7 precision 6466, is that a responsive setup?
I would say a 3.2 would spool that up a lot quicker and a power would reach for the stars.
Do you know what rear AR you have Pete? Please don't say you have a 0.6ish.
It was a 0.84 but there was talk of it being swapped for a 1.00. Never really confirmed though.
Well I did not expect you up this early, stay home ?
I think there was a .6 something and was changed to the .82 or 4 ?
After a big read of most of this thread I would say the turbo is too small for the 3.2lt Pete.
My car has the same problem making the max power, we had to reduce the boost in the top end.....however I also would have thought it would have made a bit more than that, my turbo is only a little bigger than yours (8374 0.92 EFR) and I managed 80kw more on 98 octane.
Have they done a back pressure test, this would tell you if you have a restriction from the small exhaust housing?
What I couldn't find is what revs it is at full boost (22psi)?
  • Like 1
It has no full boost at 22psi, it drops off at 4500rpm to 18.5 psi at full boost at about 7000rpm
Subboy- I suspect your car on a Dyno Dynamics would be doing well to go over 420wkw so the power difference is not quite as substantial, and the effect of a smaller turbine (yours would be more comparable to a 6266 - which btw would be far more suitable on this regardless) would be pretty substantial on a 3.2 litre.
It would be nice if there was communication from the tuner on why the drop back in boost but it seems on the fringe of plausible that it could be a contributing factor to it maybe not making quite as much as what one would think could be doable.
No matter what it's clearly a very impressive pump gas weapon and nice to think there is potentially gains to be had with further optimisation
Had my car on a Dyno Dynamics on another local tuners.....it made 458kw so not much different than the 467kw it made on the Hub Dyno.
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
