If it's the turbo selection that is causing these issues.... Everything else is irrelevant. See what the new tuner says.
You're dreaming its not out of puff & i don't know how you're jumping to that conclusion?! As history repeats you can bet these blokes haven't done their job properly AGAIN! Odds are the boost control hasn't been played with properly or they have piss weak springs in the wastegates. But falling on its ass like that at 5500 isn't showing the 6262 being all in IMO pretty sure itd taper off more gradually then just drop off the planet like that. It is a 705hp turbo FFS and hes using over 500 of it currently.
  • Like 4
Thats your conclusion.
While I don't think that turbo is necessarily the best option for this setup, I tend to agree that the turbo is not the most likely cause of what is being seen. Again a shame that there appears to not be better communication from the previous tuner.
  • Like 1
how does it go starting at low temp?
Is that not the reason xklaba didn't take his?
Never had an issue. Even down at Cootamunda in the middle of winter, left outside at the hotel. That was bloody cold that morning too.
Get the tuner to do a PROPER cold start.
The problem I have is my car was tuned to in summer where the mournings are still over 15deg so setting it up for 0 deg is a guess at best, it starts 6 deg with a bit of whinding, less then 10 seconds
It just wasn't looking like starting and at 5:30am with my fuel pump I didn't want to sit there whinding for however long it would have taking to start upsetting my already dickhead neighbours
I also have cold Denso race plugs which wouldn't cold starts
Maybe, would be pretty disappointed if the workshop didn't sort that out.
And boost can drop like that if the the rear is beyond its VE especially if manifold pressures were to rise and this would obviously crack open the gate amongst other things. I still think the .82/62 rear is way too small for a 3.2.
Pete, seriously....Don't worry about all this response rubbish, just go and buy yourself a GT42 and be done with it. Rev the f@$king thing past 3000 and be happy with the face stretch when it comes on. Been done hundreds of times before and it just works.
  • Like 1
Fair enough.
Now, I need availability near my work or home.....
or, stick with 98.
I know what you mean, I would have to drive about 200Klm to get it and it would be just about 3/4 empty when I got home.
Different deal if you are doing something special with it, fill a few cans. Thats were the flex fuel sensor will come in, use it when it suites you :yes:
I so agree
I so agree
No worries mate, all good.
Had a 80klm drive this morning to get the cobwebs out, good stuff!
Take car to Jez
End thread
Yep well this thread will only ever be more supposition until the car goes to another dyno to find out what is really going on. At least if it goes to DVS Performance he can read some of the history behind it here.
SORRY, it cannot be over until the " Final Tune " after this 3.2 build is finished, so hopefully, very soon :)
Probably will not be too much KW difference but might change were it starts kicking in ?
Never heard of an external wastegate opening due to exhaust pressure tbh, I'd consider it a design issue if it did - by function definition they are meant to block any flow until the reference pressures met targets - especially if it had both ports utilised.
In regards to VE dropping, that's just going to mean boost pressure will go up for a given airflow - the 62mm hot side is proven to flow much much more than Pete's setup is asking of it... so while I agree it's hotside is way too small for that setup (.8x twin scroll 62mm on a 3.2 - what the actual f**k? I didn't realise...) IMHO I think that explanation doesn't add up. In saying that, it's making good power and if Pete is happy with it then really all that really seems to be needed is making sure the mechanical and tune situation is on point and enjoy.
Things don't seem to be necessarily optimal, but I'm not expecting to see miraculous improvements in power - perhaps some improvement in power delivery if it turns out the intake cam proves to be excessively retarded in practice.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
