lol yeah sorry I assumed PFC....Haltec of course allows upload and download of maps too but its designed to have a single tune with multiple dimensions....eg the flex fuel sensor is a third dimension to revs and load
if it's tuned on lambda u can swap over maps automatically on the haltech from 98 to eflex whatever.
My last tune whenever i had e60 in my tank it would change over to the e85 map...
Opposite way for pump map
I'm sure you could, but you'd need a laptop and access.
I mean being able to have another tune done on the car while there was a tune was running the car.
I am sorry but I do not know how to explain it.
If they can lock your ECU, can you still have a new tune to over ride the old tune.
No one seems to know if you can have 2 tunes on a Haltech and be able to swap ?
I believe you can.
It's best to get the ethanol sensor and get a flex tune done.
The ecu will automatically adjust to the ethanol content.
Tune costs more due to more time required, but it's worth it to not worry about map switching and fuel mixing.
Depends on a range of things for sure but it occurred to me that if this turbo is good for around 400kw and generally gives its best at just over 20 psi then it's probably a very good result. No experience with a 6262 so I really don't know. Need to know what we're looking at before assessing if it's a 'good' outcome or not.
I have no experience either but I believe these turbos will make over 500kw at more than 40psi so would be keen to see it at around 30 psi. You could have some fun for a while and then turn it down if it is too much of a pig as a DD.
Of course a good outcome is what the owner (who is paying for all this) sees as good.
  • Like 1
I have to say I expected more from the tune, maybe too much ?
Aside from the issues with the misfiring etc, what were you hoping for? More response, more top end power? You always said you were after approx. 400rwkw which is roughly what you got so I'm assuming it's not the peak power.
I believe you can.
I paid top odds for the petrol tune$1600 and that seems way to high
I'm surprised at the conservative result.
The head was ported and the compression ratio was low.
I expected more.
The head was not ported, they said the head would be fine, 1mm OS valves and 8.5:1 CR
From what most said I expected more, but I will wait until I get the bug out of the tune and see how it goes :/
I expected it to go harder down low, I think I listened to some blokes with the "torque monster" bit, haha
I thought it may have been tuned to around 28 psi and 15 to 20psi on the low side. Even on the run in tune @15psi it was a good DD and only needed the limiter lifted
The PT6262 CEA is good for 700HP , I did not expect this, just wanted a Turbo that could handle more if needed.
All of the bolt ons were good for 450awkw ish , so E85 was going to be my mad time rides :) But that will have to wait :/
I think a lot of you guys are dissapointed with 380kws out of a 6262.
I dont see why...they make power with big boost...which you cant do on 98
e85 and jam 2.5bar down its throat will wake it up.
As for torque monster....its only 3.2L
No engine with only 3.2L to play with will be a low down torque monster
You can't tune past 25 on 98, if you're lucky.
You'll get heaps more on E85. e.g. my car made 100kw more with 2-3psi increase on E85, over 98
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
