The pic of Pete jamming a chilli dog or whatever up his nose is what he looked like before the build. Now he looks like this. Let this be a lesson to us to never modify cars.
Hi Bro, go to bed, no more wine for you today, hic hic :/
I was thinking of getting married again, I do not need to, I can be pissed on, harassed and tormented from the blokes on SAU and it costs me nothing, now that is much cheaper than the few $s I spent on the 34 , SO :cheers:
  • Like 1
No.
*roadbase*
You have to get your finger out and stuff the 88 into the whale, then when I finish this shit you can take me for a run to show me what a good car runs like, maybe we can get someone else to drive it , to give me a better idea :)
Ha ha. You are a crack up. At least we have the same views on marriage anyway. That must count for something.
  • Like 1
why you want bottom end so much pete? you got such a good engine build and revs to 8000rpm why not just bolt something that would kick ass from 4000rpm onward like a GTX35 cause the 3.2L should be fine as is for bottom end, then you could go to track and use 450kw's to have your fun...
I know it runs hard and I enjoy it, even when it was playing up, it was still fun to drive.
Some of you blokes may not understand but it took me a long time to get used of the car sounding like a bumble Bee , it was strange , even annoying when you had to go to 6000rpm before anything happened.
I have never done track or hill climb, I now know once these cars get going they keep going but to get the most out of a high HP skyline you need to keep the revs high or if you want to have a bit of local fun , drop it at 7000rpm and that is not a good look coming out of Woollies .
I want this car to get going ASAP , please do not say get a V8 or V12 , I have had a V12, V8 and a V6, even a 911, I like my 34, I like a stick, I like the way it feels when I drive it, I like the look of it , I like sitting in it and I will get it to do what makes me happy :)
  • Like 2
Try punting a 450kw street GTR around a track and let me know how that works out for you, I have that much power and have tried it, not a fun experience :/
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
