So Pete you have replaced
Engine
Exhaust
Turbo
Ecu
Injectors
Fuel pump
Clutch
And soon to be manifold.
What was the reason for poor response? Not much left.... Intercooler?
XKLABA- yeah fair enough, just seems a shame, a 3.2L off boost you'd think would have enough to satisfy off boost even as the VL non turbo was good, I just envisioned the 3.2L would be good then after say 3500rpm it would be an animal to the redline.... hence the GTX35.. but I have only experienced a 320kw gtst pulling form 4000rpm.. so hence my question.... I thought that was pretty ok really ..that is the little wait before the storm.. :)
Engine
Exhaust
Turbo
Ecu
Injectors
Fuel pump
Clutch
Would suck if it was just a bad tank of fuel.
Engine
Exhaust
Turbo
Ecu
Injectors
Fuel pump
Clutch
The motor works fine, the exhaust is being tweaked and the turbo ?? Maybe the manifold could be the problem for the turbo??
It is full boost now at 4600rpm and then starts to loose boost, I want it under 4000rpm and to maintain the boost and do not think that should be too hard to get.
The manifold may come on Tuesday and if it does the work can be finished and the car tuned.
So I will wait and see :)
  • Like 1
why you want bottom end so much pete? you got such a good engine build and revs to 8000rpm why not just bolt something that would kick ass from 4000rpm onward like a GTX35 cause the 3.2L should be fine as is for bottom end, then you could go to track and use 450kw's to have your fun...
It was not being built for the track.
I do not care if it is 300kw as long as I can use the 300kw as a DD, a street car that does not going until 5000rpm + , in "my mind" is a waste of a good car.
Do not get me wrong, even the way it is now, it is a fun car. It has a linear acceleration that handles easily on corners. Blokes talk about too much torque but the right foot takes care of that and your brain takes care of the rest.
This is what I want, being at full boost before 4000rpm, it is 4600 now so I think under 4k should be easy to get considering some of the problems I have had with the build once the problems have been sorted
What do you think is optimal XKLABA? Will vary from track to track obviously but interested to know based on your experience.
It really depends on the car and how it is setup, suspension tyres aero etc, it also depends on what kind of HP it makes, stock car on road tyre would be a hand full at around a genuine 350kw, my 34 has R tune suspension, sway bars and biggish brake upgrade and 295/30/18 Hankook Z221s in soft compound and I find about 380kws is controllable and could probably go to 400kw with some more practice on any given track
If you have Steve Ka's WTAC car then by all means go 450kw or more
I have not done any track work, what do you find happens after 380kw? Is the power too agressive?
You end up spending more time fighting the car to keep it straight then putting down good lap times
I went to the drags last week for shits and giggles and it had no tractions 1st 2nd and most of 3rd on 24psi which is about 440kws on a prepped track, now imagine that every time you come out of a corner and try to put the power down one a surface that isn't prepped for extra traction
Can be done don't get me wrong it's just not a fun experience if you are looking for a good lap time, 4WD skids then it is awesome fun, at 380kw I was drifting the fishhook in 4WD when it finally started to work ( not bleed completely so 4WD takes its sweet arse time to activate) at wakefield while peddling it
  • Like 1
You take things to seriously.
Let's just get to pg100
I hear what ya saying, definitely a handfull around corners.
How did you go a drags, what time/mph?
Are you sure ur 4wd is working properly? I only get a but of wheelspin in second, definitely none in 3rd gear
Have you got it set up to basically run RWD until you start pushing hard?
Best that night was 11.1@132mph with a 2.1 60" :(
Car weighed in at 1682kgs without me and I'm 108kgs
Car has gone 10.8 @132mph with a 1.7 60"
When you feel the front moving sideways as well you can be fairly sure the 4WD does work, eventually lol, it still needs more bleeding, it is just been a PITA this time for some reason :/
  • Like 1
Nah mate, it is still all factory ATTESA just I put a bolt in the back of the actuator to remove the free play in the actuator arm and haven't been aboe to get all the air out properly yet
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
