Best that night was 11.1@132mph with a 2.1 60" :(
Car weighed in at 1682kgs without me and I'm 108kgs
Car has gone 10.8 @132mph with a 1.7 60"
When you feel the front moving sideways as well you can be fairly sure the 4WD does work, eventually lol, it still needs more bleeding, it is just been a PITA this time for some reason :/
I would definitely be bleeding out ur 4wd, 2.1 60' is rwd territory not 4wd, something is not right.
Mine barely spins in 2nd on prepped track, and the only way it will spin in 3rd is with 4wd turned off.
How much power on ur 10.8second run?
You end up spending more time fighting the car to keep it straight then putting down good lap times
I went to the drags last week for shits and giggles and it had no tractions 1st 2nd and most of 3rd on 24psi which is about 440kws on a prepped track, now imagine that every time you come out of a corner and try to put the power down one a surface that isn't prepped for extra traction
Can be done don't get me wrong it's just not a fun experience if you are looking for a good lap time, 4WD skids then it is awesome fun, at 380kw I was drifting the fishhook in 4WD when it finally started to work ( not bleed completely so 4WD takes its sweet arse time to activate) at wakefield while peddling it
If that's the case, why are you going for turbos that will do 500 kW or more?
  • Like 1
It was a cold night on 295/30/18 Z221s which I just could not get heat into hence why I am putting the 265s on, there is a film clip of it launching and spinning the fronts so they are working they are just taking longer then they should to activate
It was definitely spinning all 4 through 2nd and most of 3rd as it was snaking pretty big all the way through those gears
i
Is that in a r32?
I would look at your 4wd system, i ran 10.6 sec @ 136mph on 235 federal tyres, only traction issues are off the line in 1st gear.
  • Like 1
R34, I'm going to bleed it again before wednesday but when I get back from ringwood this weekend the OS88 will be going in and I'll have to do it again
I think the problem is more the tyres and how cold the track was, stone cold semis don't work so good, I also don't have a 2WD switch so no way of getting any heat into them :/
My 34 is 280kg heavier then my 32 :/
Are both ur cars rb30?
Arent the r34 supposed to be faster reacting 4wd systems with more preload?
Maybe try some street tyres instead of the semis, i had no luck with bridgstone semis
Only 34 has 30, 32 is still stock motor stock turbos
Faster computer but still need the system to be bleed correctly to work properly
I only have 275/35/19 RS-3s as street tyres which have a much bigger diameter or two sets of semis
I'm waiting for the 265 semis to wear out so I can fit the 265/35/18 AD08Rs to those rims
You seen GTRNUR's results in the build thread pete, seems relevent to your situation some what, a 6466 that was maxing out with 98 at around 380ish , but he's getting full boost much earlier than your 4000rpm goal ...
What tyre pressure did u run?
30 rear 32 front, it is what you have to run with these tyres to get even contact across the tread
Wait whos thread is this? Lol
Pete....... Where are you? ;)
We will see 100 pages one way or another dam it :rant: lol
  • Like 1
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
