30 rear 32 front, it is what you have to run with these tyres to get even contact across the tread
We will see 100 pages one way or another dam it :rant: lol
Dont worry mate I enjoy the info while I am waiting for my job to be finished and Paul is back in action, all good :yes: :yes:
You seen GTRNUR's results in the build thread pete, seems relevent to your situation some what, a 6466 that was maxing out with 98 at around 380ish , but he's getting full boost much earlier than your 4000rpm goal ...
When did his get full boost, I will try to find it later but I do not mind maxing out under 380 kw and I am hoping for full boost under 4000rpm and think we will get it, but my expectations so far in the modifying world have been less than met, lol
Full boost at 4600rpm seems late and hopefully with the cams and cat tweaked, the 6boost manifold , a new tune???
28 psi was at 3300 I believe. That's a 6466 with a 1.00 rear.
I'm not sure about that as the dyno wasn't logging RPM. When it had the 18lb gate springs installed it would easily get to 18lb at around 3200.
To get some control though, I changed the setup to use twin port boost control with the gates and am using 10lb gate springs instead. This is bringing boost on a little slower, so probably 3500 to 20lb and I have no idea where it gets full boost as my eyes are on the road instead.
Pete's setup should be all on around 3500-3700 at most.
  • Like 1
20-22 was best results on my street tyres
Different tyres respond differently to different pressure, cause these things a 30 series they rely on tread grip as there is very little sidewall so no flex so I need to get even pressure across the tread for best traction, it also means they need heat to work and that is something I can not do in 4WD at the drag strip on a 10deg night :(
they are not the best thing for drag racing or standing starts but awsome for circiut use
yes, eyes on the road once it's on, no sightseeing , lol.
Had a bit of a look at those 6Boost Manifolds, seem like a nice unit.
Hard to find a lot of info, anyone used the 6boost or knows about them.
From what I can work out, it is the way the 6 pipes all come together and there is no real disruption of the exhaust flow ( not sure about the wording) :/
Thanks, I should have opened my PC as this laptop really is difficult at times searching on SAU, I cannot login directly or get PMs or Notifications ????
So it seems like everything, some think something is great and others think it is crap ,haha
It's to late now don't you think?
With some people liking it and others not are down to personal taste, whether they got a dodgy mani, application and a million other factors.
It is better than that Swiss cheese mani you had
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
