I know I am a boring old fart but I have not tried to turn the wick up, well up top, but with a shit load of torque, 900Nm you would think it would burn a little rubber from 6000rpm, not just a skip .
I am sure it felt stronger going from 7000rpm as a 2.6 , STOP! I do not want to hear it , hahaha
I think he means turn Jez's wick up to get the thing together and making some killerwasps asap.
you said it......................
What's there to prove, A VL block with same setup boost will come in earlier and off boost there will be more torque. What Andrew did was great and just reconfirmed what Mines did all those years ago.
People have been changing diff ratios for a 100 years to make their cars accelerate faster. Nothing new.
What was it that andrew and mines did?
Andrew changed the drivetrain ratios, put in 6 speed and kept the 5 speed diff ratios. Similar as putting shorter diff ratios in a 5 speed.
Mines changes the diff ratios in a 6 speed don't know the ratios though.
Edited by XGTRX
There are a few mods to be done to fit the manifold and it is going to be heat wrapped and I would think that would be done soon.
So I guess tomorrow or early next week it will be tossed on the Dyno and hoping for a good outcome :merli:
When Jez is happy with everything he will make up a CAI pod cover and hopefully I will never have to touch the heap again , :yes::rolleyes::whistling:
  • Like 2
can we get vids of the dyno run pete? Love hearing these things , GTRNUR's sounds awesome.. :thumbsup:
I will ask for a Vid but I wont be there, so ?
It is sort of like not going to the birth of your kids, well sort of, I hope it is not as messy, can you imagine all of those left over parts all over the floor, old manifold, injectors, nuts and bolts, you get the idea, but I am sure it will not be quite as good but second best is OK :banana:
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
