I will ask for a Vid but I wont be there, so ?
It is sort of like not going to the birth of your kids, well sort of, I hope it is not as messy, can you imagine all of those left over parts all over the floor, old manifold, injectors, nuts and bolts, you get the idea, but I am sure it will not be quite as good but second best is OK :banana:
You are a special guy!
Ok ok. I will review first.
haha, that will work, BUT can you be trusted :/
If the tune was done last I would have gone down, about 12 hours return, but it is having a pod cover made after the tune, I ask him to do it this way just in case he thinks the Turbo needed changing
  • Like 1
Hi Ben, just in case you misunderstood , I went to all of my kids births and could not be any prouder, wonderful experiences, but you can still joke about it :)
The dump pipe,, cooler and intake pipe are being fabricated, then he will welding the twin wastegate positions and then twin plumb back into the dump.
Toss it on the Dyno and if all of the problems have been fixed and worked in together he can do the pod cover, the END! well ???
  • Like 1
There's never "the end" but there comes the point where you have to say "enough"! Looking forward to the result.
Yeah Bob,but I "had enough" ages ago but as you know, if it is not right you have to keep going until it is.
After that and the car runs properly , it will be the end as there would be nothing else for me to do for a street car, good response and power , it already has great clutch, Front diff, trannie mods and a 2-Way LSD = HAPPY :)
II would expect to be able to post the Dyno next week and after I drive it home I will be able to say if it what I was after.
  • Like 2
Haha! The end....is there such a thing?
For me it's probably the gearbox;
1, R34 Getrag = money I have now
2, OS88 = money if I save up
3, R35 Transaxle = if I win Lotto this weekend!
haha, you are kidding Chris, you will never stop, a quick visit to a bank will get all of your dreams, maybe with note and a gun, LOL
Haha! I like your style Pete.... "Put all the money in the bag, my car needs a new gearbox!"
The 6 Boobs mani looks the biz.
Is that a single layer gasket sitting on there Pete......? Tell however speced that to stop being a cheap bastard and put a good multi layer one on like a Permaseal.
Edited by Sub Boy32
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
