Hello
I am researching how to put a rb26 into a r32 gts-t. One thing that I keep reading is to cut the slump off . What is the slump and where is it located? Is it the part where the front steering racks would connect to the engine for 4w drive, that is a part of the oil pan?
What would be the proper way to cut this off? Or do I just unbolt the parts? I have read that some people weld it and some don't. I've also read that some people leave it.
I also read that the oil pan has be to changed to a rb20 or rb25 one.
What I researched also is to keep the RB26 engine harness, GTR harness and dash, bolt on the rb20 ac pump, power steering pump, and use the gtr computer.
Do I have this correct? What bout sensors? I didn't see anything about what sensors to keep or change.
I went through several sources online including some from this forum.
Edited by yoshiii335
  • Like 1
Holy shit.
You really are struggling aren't you man.... How many sources refered to a slump?
The slump doesn't exist. The sump is different between awd and rwd. Which is the oil pan. Which has a diff in it for an rb26. Which you should google what differential is for an explanation. And maybe what awd is as to why there is a diff in the front.
Edited by Ben C34
^^^What he said, Judging by your many threads your mechanical knowledge is quite limited and while its good to expand your skills I suspect you won't be ready any time soon to undertake an engine transplant. If you are going to buy an RB26 and pay someone to install it in your car the cost will likely be not much less than if you were to sell your car and buy a GTR.
Holy shit.
I am trying to learn things. So even when I research you guys act like a..'s. You have no idea what I can and can't do. So for all of you who want to criticize the f is what I have to say to you!
For those of you who help, thank you
Wow, you do realise before the internet people did stuff by working it out themselves, but yet with all the information you have available to you, you have problems even being and to find and understand the info...
Spoon fed but cant chew and swallow
Yoshi,
There are reasons that several of us have advised you that for the power level and response you are wanting you should put in an RB25. Preferably a Neo. Those reasons are;
1) A 20 will be peaky and not as much fun on the street,
2) A 26 is a shit tonne more work to install, including all this crap about having to fix the sump, etc etc.
A Neo is just as good as, if not better than, a 26. Essentially the same capacity, even better head design, same oil pump and rods as a 26. And at the same time is so similar to the RB20 that things like intake paths, throttle cable, wiring, etc etc all just more or less line up with the original stuff, making the transplant that much easier. Sure, there is still of a lot of crap you need to sort out to put a Neo in, but it is still a lot easier than some of the crap you need to do for a 26.
I will admit that power steering and air-con would probably be easier if you did a 26 (depending on the donor vehicle and your choice of which anciliaries you keep from which engine), but that's about it.
If you don't know what and where a "slump" the sump is then you have a metric fark load to learn before you are even capable of considering this conversion
Again with the neo being better then a 26, proof is all i want, i know a stock neo with stock turbo is never going to make 400rwhp, i have proved a 26 will :/
  • Like 1
The fact the you don't know it's called a sump and not a slump or where it is on the engine shows how limited your knowledge of cars is and would be doing yourself a favour buy paying an expert to do the job
Area under the curve my friend. Peak HP is only one measure.
show us a dyno sheet that can match micks curve and power out put then cause none seems to be able to come up with them
Solution is simple, do what most to when they have no idea, pay a professional to do it for you.
All you need is money.
If no money, then borrow from a bank, if that fails, rob bank or sell arse or sell drugs to get money. :)
If that fails, sell car.
  • Like 1
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
