so i've got an Innovative wide band sensor and gauge to suit ( basic option ), i've set it up, calibrated it and its been working fine for 3-4 months, although now i'm getting random readings through out the air fuel ratio.
the gauge might display correctly for a little bit then will hunt from 8 to 22.1 and get stuck on 22.1 until the car is restarted and no the car doesnt lean out and stall when this happens.
i took out the sensor from the dump pipe and re-calibrated it which only fixed it momentarily and the problem came back after a day or two.
i'd like to know people's thoughts/ ideas on this issue ?
How far from the turbo outlet is the sensor?
just on the factory bung atm so right next to turbo outlet , will weld a bung at the end of the front pipe when i get round to it.
dont see how that could be a major problem as a few new cars run wideband from factory
If you have a laptop and cable try reprogramming it through LM programmer. Also check all your earth wires to it are secure.
i only re-calibrated the sensor by removing it and unpluging as the procedure, will try it through the laptop setup as i did a few months ago
Edited by Dan_J
I thought you had to tell it you were doing free air calibration but im no innovate expert
I would put the bung in pre cat (as per the installation manuals reccomendations) and go from there. You may need to buy a new sensor, for the money they cost and the peace of mind will be well worth it.
I know innovates had some issues a few years ago but cant remember if it was a problem with the sensor or the rest of the system. Dont think this is the issur but thought it was worth mentioning.
Too hot too close to the turbo. It could be getting upset and throwing the controller into a panic/confusion. Modern OEM widebands are not necessarily that close to turbo outlets!
Innovate says to place the sensor at least 60cm downstream from the turbo. Its best to place it just before the cat (any closer to the turbo and you're under the passenger footwell). There is a bit more of a cavity in the body around the cat area. It can be very tricky to get the exact angle, but you want it pointing as vertical as possible so that condensation doesn't sit in the sensor.
Is this the Innovate MTX-L?
If so, I think there's an issue with the design of the gauge causing it to kill sensors. I'm on my 3rd gauge and 2nd sensor in under 2 years.
Not to mention the car doesn't get driven often.
I've read on evolutionm that the gauge overheats the heater inside the sensor causing premature death.. at the same time the gauge will often die too.
Luckily I bought mine through a local dealer (Game On Motorsports) so I had local support/warranty.
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
