I have a 1995 R33 GTR, and recently, I have seen it develop an issue relating to the turbos. This is what has been happening:
Light throttle, the car shudders and jerks a little bit, but when I accelerate hard, the jerking goes away. This only happens around 2000-3500 rpm range, and only under light throttle. If I let go of the accelerator, the shuddering goes away.
I have two boost gauges, possibly one for each of the turbos. One shows a slightly higher reading than the other, which makes me wonder why it is so. When I bought the car a few months ago, both gauges used to show almost the same reading.
The two BOVs seem to go off in sequence. One goes off first and then a second later, the other goes off. This wasnt the case a couple of months back.
I am stumped as to what the cause is, how to look for it, and what to check. Could someone please help?
Thanks
Munib
Never occurred to me that the AFMs could cause the readings on the boost gauges to be different or the BOVs to go off one after the other. Do you think that could be an issue? When it is idling and I give it gas, one boost gauge jumps to 0 and the other goes a little futher up. And when I turn the car off, the boost gauge that goes to 0 goes back to 0, while thge other one stays much lower. Arent they both supposed to go back to zero pressure (no vacuum or boost) when the car is off?
Could this be caused by a leak or faulty coil(s)?
How is what I am describing (the shudder and jerking) different from turbo shuffle? Or is it?
It's your AFMs. Possibly a loose afm plug but most likely it needs to be replaced.
Boost gauges go out of calibration, but they should be reading off the same system. What I mean is that you have two turbos but they feed into a single intake system. I assume there were two installed to read the pressure drop across the inter cooler... maybe?
I wasa thinking that the persopn who I bought the car from in Japan had two boost gauges to measure the boost pressure before the intercooler, which hardly makes any sense. So I wonder why two gauges in the first place? Assuming your point about one auge measuring pressure before and the other after, the intercooler, is valid, how does it correspond to the shuddering, in that the difference between the two gauges is much higher than it was, say, a week ago?
I am wondering if it has ANYTHING to do with the possibility of onw of the turbos not getting enough exhaust pressure, so it is spinning slower, and therefore, producing less pressure. If that were the case, it would point to one or more cylinders not firing properly.
Or is the above totally wrong? I would rather it be a dirty MAF, than a faulty set of coils or a timing belt issue (skipped a tooth or two). The idle is also slightly rougher than a few days ago. Could this be related to poor combustion/ignition in a cylnder?
I appreciate any and all inputs.
If both boost gauges don't both go back to the same reading when the car is switched off then one is faulty
After reading your posts I strongly suggest taking the car to a professional
You skipped the first part of my post. I had similar issues and it was the MAFs. Especially the shuttering at 2000-3500, it's a limp mode that in that rpm range is specific to MAF failure.
Forget about your boost gauges for right now and take care of you MAF issue.
@brett: I understand that they both should go back to the same level when the car switched off....and I fixed it, yay!!
However, I don't feel my ignorance in the matter requires me to take the car to a pro at this stage. Yes, if I am unable to identify the real cause and cannot fix it, will I do that.
@aaron: The limp mode generally doesn't allow the car to rev past 3000 rpm or thereabouts. Mine revs just fine. The slight jerking only happens in gears 3-5 in that rpm range and once I am past the 3000-3500 rpm range, it runs great. In addition, the car doesn't do it in that rpm range in second or first gears, possibly because there is a higher level of load. I am feeling that this might have something to do with the load levels or the TPS settings? I have had many R32s and never had to deal with this issue with them. Wondering if there is something different in the R33s. I admit that since this car was already modified, and I am still discovering the extent of the mods, I might not know everything about her.
I just drove her to work today, and other than the jerking around 2500-3500 rpm in gears 3-5, it was great. All 6 cylinders seem to be firing, and the car is building boost well. I will try to clean the MAFs soon and see what change that causes.
Thank you both for your inputs. Please do keep the suggestions coming in.
Munib
Ok, I miss understood the symptoms. Just a heads up though, as my mafs were going out they had very similar symptoms although it was apparent in all the gears, not only in 3-5. Usually the car would jerk a few times then accelerate. Usually this occurred after I was stopped and seemed to be a result of heat soak? In addition to cleaning you may want to have the mafs tested and check the ground on plugs.
A lot of black soot comes out the exhaust when I start the car in the mornings. It seems she is running a bit richer than normal, so that might be causing the plugs to foul up, especially in the rear 3 cylinders, and subsequently, the rear turbo might not be getting a stronger exhaust flow. I intend to try out the coils when it gets a little warmer, to see if the spark is strong or weak in all of them.
Other than checking the coils and plugs, along with the ignitor, and the MAFs, what else should I check? Is there a write-up on how to check the TPS voltage properly on the car?
Could a boost leak also cause this kind of jerking, which goes way when there is enough velocity in the charge pipe that prevents the air from escaping?
I have already ruled out the fuel pump and CAS as the causes, since they would make the car undriveable under any level of load.
The MAFs are fine. I checked and cleaned them up. The jerking continues, and seems to happen only under partial throttle, when the car has warmed up. I am thinking coils/coil harness or TPS. The plugs are brand new.
Also, the turbos spool up as soon as I press the throttle, and upon letting go, I hear the swoosh swoosh of the BOVs, but I hear two sounds - one after the other. That doesn't seem normal to me. My R32s never had two BOV sounds. What does that mean?
Thanks for the inputs.
I'm on my second set (R33 GT-R ones). Original solder fixed AFMs lasted about a year. Current ones are okay but not 100% with them.
I should fix my Nistune up and throw the aftermarket AFMs on there.
How wrong is it for me to assume that since the jerking happens only when the car is running hot, that it relates to coils and not the MAFs?
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
