Hi everyone.
im coming to this forum in need of great assistance lol
ive been reading posts from all over the forums about rb's.
ive tried putting this question on Zilvia.net but no one could help
so here it is.
i have a 96 s14 with an Rb25det Series 1.
im using wiring specialties harness .
Freddy intake
FMIC
MBC.
Rb20 FLASHED ECU
now for some odd reason my car has poor performance at 15 degrees timing
it drives fine idles ok and there are no hickups to the powerband other than it being rediculously slow.
now i have fully advanced the timing and it runs OK. i can barely pull from my buddys stock 350z when im running 12psi.
at stock psi its still slow lol
things ive tried:
Checked timing belt at least 5 times to be sure it wasnt a tooth off.
replaced maf cause i had a bad one.
changed plugs gapped down to .26
waiting to try my buddys CAS so see if mine is f'd up
i havent had a chance to see if my ecu is pulling timing when high revving with a timing light
my main concern is why do i have to run fully advanced timing ?
btw at 15* if i try to run 12 psi it detonates like crazy.
there are no ecu codes
no vacuum leaks
no boost leaks.
my buddys stock 1jz s13 is way faster than my rb. wth
any help greaty appreciated
https://www.sau.com.au/forums/topic/455439-rb25-s14-advanced-timing/
I think .26mm plug gap is WAAAAYYYY to small. Your engine should be capable of using near stock gap of 1.1mm. Maybe 1mm should be the least you would need.
Some timing lights give a reading double the actual timing. The safest way to get a proper timing is to use an old spark plug lead inserted between #1 coil and #1 spark plug, then set the timing "old school".
And was the ecu flashed on a dyno, or is it something someone says worked in another car?
These were pretty much my thoughts
You dont have the locator broken off the cam and have the CAS a tooth out?
The ECU was flashed to run 12psi? If it were me id get a 25 ECU and see if that improves things. Sounds like it would run better with a stock ECU anyway. Turn boost down to around 7psi
Edited by 89CAL
I've tried running with the stock ecu and it
Idles horribly rough to where it stalls.
But driving it on stock boost it feels Ok.
Yes that is how I checked timing.
I inserted a plug wire into coil #1 and set at 15* after disconnecting the tps
As far as the vvt I haven't checked anything for that yet.
This ecu is just flashed to run stock rb25 but I'm using a boost controller to creep the boost to 12 psi.
Yes I'm waiting to try another cas maybe tomorrow cause my buddy has an s2 rb25.
The harness continuity should be good since I'm using wiring specialties harness, but nevertheless thats not to say it can't be f*d up haha
Another thing I'm going to try is the knock sensors, maybe its sending a false signal to the ecu.
Compression ratios are
130
130
130
135
129
130
I don't remember if that was warmed up or not lol
What's happening with the VVT and the 20 ecu?
This! Latest Nistune stuff will allow RB20 ECU to run VCT, but as far as I know it is not possible to make it happen without Nistune. Ergo this RB25 is running without VCT. And that means that the fuel and timing maps both are not optimised in the half of the map where VCT is not working properly. Therefore it is not running "stock" maps in quite the way that it would run them if VCT was working. This might not explain all of this engine's problems, but it would certainly explain why it doesn't drive nice.
Edited by GTSBoy
i have removed the Catalyst and im running a 3" straight pipe from the turbo back
yes it did run a little better then the rb20 ecu, sounded quieter and felt like a tab bit
more power.
then with the stock ecu i moved the timing to 15* and it ran super slow as hell and idles like shit.
my check engine light was even blinking lol i didnt even know it works lol
so only fully advanced does the car feel ok.
im going to try a CAS tomorrow
