Hi everyone.
im coming to this forum in need of great assistance lol
ive been reading posts from all over the forums about rb's.
ive tried putting this question on Zilvia.net but no one could help
so here it is.
i have a 96 s14 with an Rb25det Series 1.
im using wiring specialties harness .
Freddy intake
FMIC
MBC.
Rb20 FLASHED ECU
now for some odd reason my car has poor performance at 15 degrees timing
it drives fine idles ok and there are no hickups to the powerband other than it being rediculously slow.
now i have fully advanced the timing and it runs OK. i can barely pull from my buddys stock 350z when im running 12psi.
at stock psi its still slow lol
things ive tried:
Checked timing belt at least 5 times to be sure it wasnt a tooth off.
replaced maf cause i had a bad one.
changed plugs gapped down to .26
waiting to try my buddys CAS so see if mine is f'd up
i havent had a chance to see if my ecu is pulling timing when high revving with a timing light
my main concern is why do i have to run fully advanced timing ?
btw at 15* if i try to run 12 psi it detonates like crazy.
there are no ecu codes
no vacuum leaks
no boost leaks.
my buddys stock 1jz s13 is way faster than my rb. wth
any help greaty appreciated
https://www.sau.com.au/forums/topic/455439-rb25-s14-advanced-timing/
I think .26mm plug gap is WAAAAYYYY to small. Your engine should be capable of using near stock gap of 1.1mm. Maybe 1mm should be the least you would need.
Some timing lights give a reading double the actual timing. The safest way to get a proper timing is to use an old spark plug lead inserted between #1 coil and #1 spark plug, then set the timing "old school".
And was the ecu flashed on a dyno, or is it something someone says worked in another car?
These were pretty much my thoughts
You dont have the locator broken off the cam and have the CAS a tooth out?
The ECU was flashed to run 12psi? If it were me id get a 25 ECU and see if that improves things. Sounds like it would run better with a stock ECU anyway. Turn boost down to around 7psi
Edited by 89CAL
I've tried running with the stock ecu and it
Idles horribly rough to where it stalls.
But driving it on stock boost it feels Ok.
Yes that is how I checked timing.
I inserted a plug wire into coil #1 and set at 15* after disconnecting the tps
As far as the vvt I haven't checked anything for that yet.
This ecu is just flashed to run stock rb25 but I'm using a boost controller to creep the boost to 12 psi.
Yes I'm waiting to try another cas maybe tomorrow cause my buddy has an s2 rb25.
The harness continuity should be good since I'm using wiring specialties harness, but nevertheless thats not to say it can't be f*d up haha
Another thing I'm going to try is the knock sensors, maybe its sending a false signal to the ecu.
Compression ratios are
130
130
130
135
129
130
I don't remember if that was warmed up or not lol
What's happening with the VVT and the 20 ecu?
This! Latest Nistune stuff will allow RB20 ECU to run VCT, but as far as I know it is not possible to make it happen without Nistune. Ergo this RB25 is running without VCT. And that means that the fuel and timing maps both are not optimised in the half of the map where VCT is not working properly. Therefore it is not running "stock" maps in quite the way that it would run them if VCT was working. This might not explain all of this engine's problems, but it would certainly explain why it doesn't drive nice.
Edited by GTSBoy
i have removed the Catalyst and im running a 3" straight pipe from the turbo back
yes it did run a little better then the rb20 ecu, sounded quieter and felt like a tab bit
more power.
then with the stock ecu i moved the timing to 15* and it ran super slow as hell and idles like shit.
my check engine light was even blinking lol i didnt even know it works lol
so only fully advanced does the car feel ok.
im going to try a CAS tomorrow
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
