The car starts up fine but the sound coming from the head is super unnverving. I'm wondering if I have a bent valve or something. I pulled the covers and I saw no sludge or anything. The oil is super clean (I changed it last summer and put 20 miles max on the car. it hardly gets driven). I know its tough to gauge what could be wrong with the vehicle based on sound but here is a video of the noise. Remember this noise is speed dependent.
https://youtu.be/HWnxb16Bfr4
What would my next course of action be? Would a compression test tell me if I have a bent valve or anything? She starts and idles fine and drives fine although the only driving I do is from the end of my driveway back into my garage. Took the valve covers off to see if I saw anything irregular such as sludge or anything but everything is super clean. Like I said since putting this motor together, i've put a maximum of 100 miles on it in 2 years since I finished the car.
I'm from the states but I figure I would ask you guys because you guys see these motors more than we do here in the states. Any info would be much appreciated.
Sounds like there's two different noises, one when put under sudden load at 0:05 which sounds like a knocking, that noise ive never heard before, the ticking noises I would bet are the lifters , maybe a few have collapsed and not pumping back up..
What was done to the head/motor when built? are you using big camshafts?
Brief history of the car. Did fresh internals of the motor. Bottom end was completely worked over. Head is just ported and polished. I put it in the car and life happened and so the car sat more than it was driven. Camshafts are stock. I want my toy back so I am starting to get back into the car. I believe the timing might be a tad off so that could be the knocking you hear. I'm hoping the ticking/knocking is lifters. I plan pulling the lifters this week and seeing if I can clean/revive them. and putting things back together. I also notice that one of the bolts was snapped off the cam angle sensor.
Its been so long since I've worked on the motor that its kind of scaring me to get back into it. Mainly getting the timing right such as getting this at TDC and what not. I've read that I don't want the motor at TDC when I reinstall the cams. It's scary stuff to get in to. The last go around I had someone who knew what he was doing but he has since moved away. It also helped that the motor was out of the car. I'd rather not have to pull the motor if all I am fixing is lifters and timing the motor correctly.
Does it have good oil pressure and the right viscosity oil?
I've always put 10w30 in it but might oil pressure gauge is a little suspect (it was used). I'll buy a new one right now. 10w30 is the correct oil I should be using correct?
Yeah my thinking is that when the lifters are held under load and sit for long periods is they get bled and stick in position? so will probably need taken out and soaked then pumped up with fresh oil,
There's heaps of threads on lifter problems on here and someone else might have more advise, but if mine id flush, then new oil, get the engine hot and let run for 20mins and see if the lifter free's up, keeping the revs low to avoid damage, but its your call really.
Edited by AngryRB
Yea thats my plan. Ill take the lifters out and work them as best as I can and then reinstall and see where that takes me.
Edited by Inline6Silvia
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
