Hey guys I have been searching and searching for the correct turbo to put on but cannot find it..
I have a rb25det, has your usual bolt ons but has stock internals..
I am looking for the best/quickest spooling turbo for skidding/drifting, I do not want to hi-flow the current as I am looking at going a 6boost top mounted setup with a external wastegate..
What would be the best turbo to run, the car is only driven 2-3 times a week but gets driven hard when it does.
Opinions on the GTX3076r,GT3076r and GT3071r?
https://www.sau.com.au/forums/topic/455469-best-turbo-for-rb25det/
There is a whole f**king thread dedicated to RB25 dyno results that is 53 pages long.
How about looking at that for a start and seeing some different results from other people's setups.
In the end the choice is yours personally anyway so someone could have an entirely different opinion on each turbo.
A turbo doesn't have to be that large for drifting/skidding so you wouldn't even need one as large as you mentioned because you want response.
Look through the RB25 turbo thread and guaranteed you will find something you like/want.
  • Like 1
HKS GT-RS for 250-260rwkw perfect for drifting on 98.
300rwkw ++ on e85..
HKS 2835 PRO S FOR 280RWKW+
These two twos are the most responsive on the market for these power figures.
Overall awesome power curve aswell.
Jesse Streeter just sent me A GTRS Delivered for $2600.
Cheapest you'll find anywhere.
  • Like 1
If you are going to be using it internally gated bolton turbo and expect the most response out of it I do recommend our ATR43SS1PU, this turbo performs the identical way as the standard 21U high flow, it makes 20psi by 3400RPM, which is your factory turbo's response that peeks around 310rwkws on E85 fuel or about 265rwkws on Pump.
But if you are only looking to keep it as a factory bolt on temporary terms and expect a huge jump in HP after external gate and high mount is installed, I would recommend our ATR43G4SAT turbo, This turbo has similar response to a 3076 that peeks 20psi by 3800RPM, capable of making around 312rwkws on pump 98 fuel using street legal return flow cooler, and good enough to peek 420rwkws on a high mount E85 setup.
Both turbos has detachable rear dump adaptor, so it can be high mounted or low mounted without too much trouble on the exhaust piping.
I've got a Oxford dictionary pages worth of dyno reading with different turbo combinations specifically engineered for a Rb25det engine, you are welcome to give me a ring to go through couple of more specific configurations for your needs.
if money is no problem, then GTX3076 will be a light switch at 4000rpm and will take you upto 400kw's, but silly not to get a hypergear, use the money saved for tyres...
Edited by AngryRB
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
