Hi,
I own a r32 gts-t at the moment and I'm tying up between going for an exemption or selling so i wanted to come on here and just ask around on what would be the possibilities of actually getting it passed with the rta. The gts-t being banned though it comes under the 130kw/t rules does my head in so i was thinking would there be the option of getting the car dynoed + weigh bridge cert just to show some figures for the rta and prove that it comes under laws? Also its stocker then your mums prius so would that benefit me in anyway? Another option is im currently studying at uni and my dad ownes a company car whilst my mum ownes her own car and uses it for work so that limits me to the gts-t, would that be an option?
cheers.
https://www.sau.com.au/forums/topic/455477-r32-exemption/
Hey mate if the car is banned it's banned. no way around it unfortunately.
There are certain cars that have been allowed as they fall under the 130kw/tonne limit. However sports cars like skylines are still disallowed. It just means you can drive your mum's VW TSI
https://www.sau.com.au/forums/topic/455477-r32-exemption/#findComment-7513214
A bit of a crap solution, but dereg the car and buy a shitty daily. Drive for 3 years with clean record, get full license, re-register car and enjoy.
R32s are holding their value somewhat, but if you're super keen to have one then keep it. Otherwise, sell and drive a nicer daily. In 3 years time other newer turbo cars will be cheaper.
https://www.sau.com.au/forums/topic/455477-r32-exemption/#findComment-7513536
I have read the S14's are p plate legal, I haven't checked the site, but it's a good turbo option for P platers. Heaps of wheel choice, body kits and dose, P platers dream.
Just checked, S14 and 15 are allowed. Pretty awesome P plate cars if you can handle or like the sound they make.
Edited by FordyR31
https://www.sau.com.au/forums/topic/455477-r32-exemption/#findComment-7514154
All turbo imports (at least from Japan) are still under a blanket ban. The S14 and S15 that are legal and permitted are the ADM models. A JDM S15 is banned compared to a ADM S15. So Skylines don't fall under the power to weight rule.
https://www.sau.com.au/forums/topic/455477-r32-exemption/#findComment-7515324
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
