  • Replies 60
We've got a Autech 260RS at the mo.
They run elec Hicas simialr to a R33 GTR, but different.. under the rack as opposed to on the back.
Motors out for forgies, turbos etc at the mo :rofl:
Excellent, what size wheels and tyres does it have?
I'd be keen to see a Stagea section, and I'd be just as keen to see a Stagea in the flesh - I wouldn't mind buying one in the future if they're nice and practical... I'm sure the section will become more relevant as the Stag becomes more popular (and I hope this is more an issue of "when" rather than "if").
They'd make a nice sleeper.
Has anyone seen how good they look with R-34 GTR mags on them? Brisbane Street Machines have a dark blue one for sale, and the wheels really set it off well!: :rofl:
Pics please, SydneyKid
Nick T.
Its got the factory Autech wheels on it. +35s on the front and +20s on the rear.
I'll get the exact rim/tyre size tomorrow.. you can't go very big on them unfortunatley as the guards won't allow it. ;(
Factory kit, wheels etc with a inch or so taken out of ride hight.. looks cool! ;)
Will post some pics when I get time.
Few liitle mods we've done to it like R32 spring in the transfer case.. = RWD on demand. r33 has a percantage of drive tot he fronts at all time which means cooked cases with the the fuse out.. R32 spring allows it to be 100% RWD :rofl:
Pics please, SydneyKid Nick T.
No problems, Nick. It is supposed to be on the transporter tomorrow. A few days in the panel shop to touch up the scratches and paint the white door blue. Thank's to the totally illogical DOTARS beaurocrats. :rofl:
did you change the door with the different intrusion bar???
i think stagea should have its own permanent thread... i had put that in suggestion section ...before i found this thread...which is my point really
we need our own ...please
Yep, found a white one the same as the other 3, except the car is blue. In trying to find an upside for spending $1K for no good reason, the only one I can find is gives me an excuse to fix up a few of the little scatches and bumps a 7 year old car picks up. While the blue paint is in the gun, so to speak. :uh-huh:
Thanks to DOTARS I have had to replace a rear door with stronger intrusion bars that complies to the later (tougher) standard, with a door that complies to earlier (less tough) standards. I don't know about you, but that makes absolutely no sense to me. :confused:
Enough bad news, the good news is it is on the truck and will be here early next week. :D
No one has the crush test ADR 29 for the later model yet...which means another stagea ..later model will have to be destroyed...
their farkin mad :headspin:
SK, my friend has just brought in a red '97 Stagea. It has stock R33 GTR rims on it, I'll try and get a pic of it :)
I'll post some pics of my 97 blue stagea
stock wheels
K&N panel
stock exhaust
stock suspension - bilsteins & springs soon (anybody got info on springs)
2 sunroofs
satellite nav (useful if I ship the car back to japan and drive it around there :wassup:
No compliancing issues, from MJR Motorsport in Brisbane.
Is sydneykid doing his own ??
Was going to get the NEO version, but was worried about DOTARS compliance as most people were doing the pre NEO versions. I was glad I didn't go for the NEO as it would probably still be in the shop.
Very pleased, comfortable sleeper. A bit slow off the mark but 100-140kph acceleration is very good indeed. Just needs
firmer suspension
a bit lower
decent 17" R34 wheels would be really nice (any offers ?)
decent exhaust (3")
decent intercooler and a little bit more boost (10lb)
would like 160KW at the wheels, but will need more mods
cheers
Michael Q
[email protected]
How wide are the Autech wheels, I have a couple of sets of 17 X 8's as they are the same as we use on the race cars with 245/45/17's on them. They should fit, OK? :confused:
No, definitely not doing my own compliance. The paperwork (and dealing the beauroKraps) would drive me crazy. :headspin:
Have you had yours on the dyno yet Michael? I am wondering how much they loose through the auto and 4wd.
My target is 200 awkw :burnout: , I have ready to go on;
GCG ball bearing hi flow turbo
Split dump
Hi flow cat
3" exhaust
Autospeed (Norgren valves X 2) boost controller
Pipercross panel filter
CAI
Exhaust camshaft pulley
Plus .............
Konis (as soon as I work out if they are R33 or R34 or neither) :boinkcar:
Front and rear stabilser bars (I think the R33 GTR ones fit).
I will design up a HICAS eliminator and get our race team fabricator to machine one up out of billet aluminium (same as we have on the R32's).
SAFC from Negun is on its way.
Hope the brakes are up to it, if not I will dig up a set of R33 GTR callipers (front and rear) and a set of DBA slotted rotors. Plenty of good pads lying around from the race cars, that should stop it. :aroused:
I am getting carried away, aren't I? :jump:
    • The exhaust gases are at their highest temperature as they leave the exhaust port and enter the manifold. They cool as they flow through the manifold because they transfer heat to the manifold and the manifold loses heat to the surrounding environment. Thus, inevitably, the exhaust gases are cooler as they enter the turbo compared to when they entered the exhaust manifold. So, yes, the exhaust manifold can easily get as hot as the turbine housing. Having said that, you will generally see the highest temperatures where the exhaust gases have to slow down or they are concentrated into one area - which is usually the collector on the manifold and in the turbine housing, because the gases slam into the metal at those places, increasing the convective heat transfer coefficient and transferring even more heat to the metal than they might just flowing past elsewhere. Exhaust manifold heat shields are a good idea - certainly for the stock manifold they are there from the factory. People seldom have anything like that on a tubular manifold because they are hard to achieve. Some might wrap a tube manifold with fibreglass tape - but this has a reputation of leading to cracked welds. The best case is generally to put ceramic coating onto the manifold to prevent it getting as hot (internal coating) and radiating/convecting heat into the bay (external coating). All the real heat from a turbo comes from the exhaust side. The gases entering are at ~800-900°C and the steel/iron gets nearly that hot. The compressor side is only going to heat the charge air up to <<200°C (typically not much more than 100°C). So that's nothing, by comparison. The compressor is not a significant source of engine bay heat.
    • Late to the party, specifically joined this forum as I just bought one of these and this thread has been a gold mine of info. If the OP is still around, mind if I ask what gas you been putting in yours? Mine has a Japanese sticker in the cap saying premium but it seems to get way worse mileage on premium (95) than 91. I always thought it was meant to be the other way round🤷 I do think Nissans claimed "6l/100km" is a bit fantastical 😂
    • Does exhaust manifold get hot as turno exhuast side? I have a turbo cover to managr heat in the engine bay but  nothing is covering the exhaust manifold before turbo   i know as turbo does compress air, the temp does go up however does that mean exhaust manifold would be as hot?
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
