Interesting story . My take .
I don't think any RB25 was designed at Nissan to be a real power house in that engine family . They certainly didn't use it to go racing with .
A lot of things could be affecting your power and boosting characteristics and one I reckon could be the 25s inlet manifold design . What Nissan wanted was reasonable power output but more importantly good part throttle torque because that's what 90% of a road engines life is spent at . Its basically a hole on one side and six on the other so when you try to feed really high airflows through it isn't ideal . Nissan wouldn't have gone to the trouble they did with the 26s manifold if the far simpler 25s effort worked well enough .
1 hole, into 8 holes
3000hp
  • Like 1
1 hole in the middle feeding 6 holes is more balanced than 1 big hole on 1 end feeding 6.
Turbo F1 era ran 1 hole in the middle feeding 4 with a log design intake manifold.
That was more a case of even air disributon and tuning the intake.
ITB were the best way of getting good throttle response.
Edited by GTRPSI
Glad to see it's not just confusing me :P.
Note: Before the engine was rebuilt the same spec turbo did this at 22-25-29 style PSI (per gear).
The guys doing the head stated the previous job was shit and theirs would flow way better.
Picked up a fair whack of response, and well, more powers for way less boost.
It may just be that they're right, and the thing is just too small/can't create resistance to flow in the head.
I imagine if you put a GTX3076 on a LS1, it would not create 30psi no matter what you do with it.
My main worry is what boost I should set the gate to, to avoid overspinning and frying the thing. I guess whatever boost level makes the power the turbo is rated at? (for lack of any other idea)
What does it do on a dyno
What boost does it run to make 380rwkw?
Same as on road, or is it going higher on the road due
To a lot more load?
Be better road tuning it and seeing how fuel it uses to determine
Boost pressure if its different on road.
Cheers
Darren
If it's a new garrett turbo I wouldn't imagine excessive shaft speed would be a large concern unless you are trying to run 95 psi through or some spastic number. The gate pressure is the target before it diverts excess pressure, ie "shaft speed control". As long as you have a target on the compressor map it should be within its engineered limits. The most likely failure would be oil contamination or dirt in the intake which gets into the bearings. IMHO these would more likely to kill a new garrett turbocharger.
Not being able to reach consistent boost in all gears sounds like something is mismatched. There's no reason you can only make 20 psi in gear 3 vs gear 4 for example. Think of psi as your turbo shaft speed. If the engine and setup is matched correctly, or not mismatched then your shaft speed should hit its target no problems. Of course if u are outside the engineering limits, ie expecting 80psi then no hope but at normal levels it should be consistent. My evo makes 19psi in every gear, why shouldn't it?
Reading through your posts Kinkstaah, you mention the boost as 17, 20 and 22psi through the first 3 gears, what is it in 4th and 5th? Or did my reading comprehension let me down?
Without getting technical, I assume you're confident that the car isn't just traction limited in the lower gears? That would be the 100% simplest explanation but I didn't see it mentioned in your previous posts. Or slippage somewhere else in the driveline? Even if the mechanical engine load is absolutely identical through the gears (unlikely even with perfect traction, level road etc.), remember that the aerodynamic load will be higher in the higher gears
Depending on what you list the boost as in 4/5th gear, I don't think what your observing wouldn't necessarily be an "issue". For example, nobody has yet touched on the different locations that you are reading the intake pressure from vs where the wastegate pressure is being observed from, and I'd guess one is reading static pressure, the other total pressure (static + velocity pressure). What I'm getting at is its possible that the difference in airflow through the engine (what actually matters) in different gears might be hardly varying, yet producing noticeably different pressure readings.
Edited by YawRate
I agree with boost leak or just something flat wrong with the exhaust manifold or design. What manifold is it?? How is the wastegate plumbed? Any pictures?
But yes boost leak starts to sound like a really good idea. And I agree that turbo is SCREAMING if it is doing what you say with a boost leak. Block off your BOV and go for a ride...could be something wrong with it and you just aren't seeing it because you are looking in the wrong place for the problem (that or the BOV is only leaking at high boost!).
That turbo on a stroker should make pretty much full boost straight off of a decent stall with an auto!
Edited by HarrisRacing
He's making the same power on lower boost, an RB30 with GT3076 makes 300kw's at 14psi?? an RB25 does it at 18psi usually on 98, that seems to be a fact, so seems logical that the RB30 breaths so much that its outflowing and running the GT30 into the limits , it just can't create that pressure when its being flowed out so efficiently???? ( hence shaft speed) its still making the same power though so there cant be much of a leak happening, must be just about maxing out surely...
Edited by AngryRB
When you get boost leaks with modern turbos, power honestly doesnt drop to
Much up top like people here think
so saying something is in ballpark power wise doesnt mean much
What you do lose is area under the curve. And i can tell you not many dyno
Operators pick it up on the dyno. Ive always found playing around on rd picks up that stuff. Dynoes do not load a car up like on road. Even on the harshest ramp rate. Experienced it many times myself..
My last build did same thing and was blowoff valve. Boost went from 21 to 27psi in midrange once fixed. Gate woudnt open in lower gears
power on dyno was within 10rwkw as what youd expect
its harder to pick up with autos due to load applied and the way loads applied...
Cheers
Darren
I pressure tested his intake for him yesterday, nothing leaking much. The gasket between the plenum halves was bubbling away as usual (although it was only a slow leak)
Back to the drawing board, seems it just can't supply enough air to make the target boost as Mark said above, or it's only leaking at WOT which makes it hard to pinpoint.
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
