To add on to that - by 'slow leak' we are talking it'll drop 1psi every 3-4 seconds and otherwise hold air from an air compressor fine... an air compressor which is switched off once boost was reached. (so not constantly being fed, and leaking)
I showed trent on the dyno, this happens in Vacuum as well. You can be sitting at say, -10mmhg at a constant speed, and shift from 1-2-3-4 and the pressure in the manifold will change according to gear, regardless of anything else.
When testing with springs on the wastegate (no boost controller) the wastegate will OPEN at say, 15psi in 2nd, then open at 20psi in 3rd.
f**k me if anyone can explain how this is happening, all assumptions now assume it's an auto transmission thing, as opposed to anything turbo related.
What the ?!?!
Maybe the wastegate diaphragm is bad or something? Is the turbo in good shape?
I'm perplexed as well.
What exactly are you using to log / read boost? Mechanical gauge or electric?
Edited by HarrisRacing
Well the pressure in the manifold will likely be changing with load/gearing, so the wastegate will open at different psi due to this pressure change behind the gate.
The diaphragm is perfect, I checked that when I swapped in the new spring. The turbo is brand new. Logging on the Haltech with a mechanical gauge as backup.
The Haltech was in the front reg fitting on the plenum, not sure where the mechanical one was plumbed.
The tuner just wants to see a consistent boost curve, he doesn't care if there is .5 or 50 psi drop over the cooler, but I agree, it must be close to maxing the core's flow. Wouldn't be hard to shove the mechanical onto the compressor cover and have a look Greg...
How do you test whether a bov is leaking (a plumb back bov)? Do you just block off where it returns to the intake, and leave the return line open after the valve, pressurise the intake and see if it leaks?
Piece of coke can sandwiched in the BOV's flange and gasket.
Where does the pressure source for the wastegate come from? Ive seen similar when its taken from the manifold and not from the compressor side.
Is the Haltech running Closed or Open Loop boost control? If its running Open Loop and the Base Duty table hasn't been configured correctly, it will have the exact symptoms you explain. The engine doesn't load up the same in the lower gears as it does in the higher gears where its tuned, so it uses a slightly different area of the table, which may command a lesser duty cycle on the solenoid.
Closed loop boost control with a correctly set base table will alleviate this.
Pressure source is about 1mm infront of the throttle body.
It happens in Closed loop.
It happens with a boost controller set to 0 duty (spring pressure) or the ECU wanting 0psi boost.
It happens in vacuum.
It has all the hallmarks of an intake leak or restriction, but it was working fine before the engine build, and nothing else has changed afaik.
Greg, take a coke can to block the BOV on the next tune.
This behaviour has happened on multiple turbos, multiple engines, in multiple cars.
However, the Bov (which is an aftermarket Turbosmart BOV) has been consistent across the setup.
So I'll block it off for the sake of the argument, and report back at some time in the future, though obviously I will want to run a BOV in general, so if it 'fixes' it then I have no idea how to actually fix it.
  • 1 month later...
Greg has a larger turbo on the way, GTX35.
Seems the ported head and increased capacity now requires a larger turbo to get even the same power output he had before, a result of slowing the gas speeds down I assume. His 400kw external gate GTX3076 setup will be up for sale now I guess, perfect for an RB25.
Didn't the motor make the same power (or even 5kw more) than before? With 10psi less boost. (Partly due to compression ratio increase)
I just want to mention that the engine builders suggested the turbo was too small for the desired power figures, and so too did a Garrett rep who comes around the engine shop. I'm not saying a bigger turbo will sort every issue, but it was thrown out there as a suggestion pretty early on.
It initially made the same power (375kw) at 7-8 less boost but after fixing boost leaks and hunting everything down (and Trent upgrading his dyno so it can actually run WOT) for a full pull...
It made about 365ke, but peak power is at like 3900 rpm now.. Which it holds until about 6k then falls away and gets wavy and valve floaty. So the limiter is now lower and as mentioned, going a larger hot side.
The peculiarities of boost in gears remains in any case, nothing has changed in so far as the original post on the topic..
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
