The guys at Autoblog have recently added a few posts on both the Subaru BZR tS and the Forester tS.
From what I understand, the tS models will sit below the STi models (even though both of these cars are branded with STi badges.)
The BRZ first;
These calipers look fantastic although the overall disc size seems a little underwhelming.
The seats are Recaro's with STi branding.
Only the second tS badge I can see in the pictures.
The BRZ looks awesome with the black wheels and wing, theres more STi badges than you could poke a stick at. It has 200HP which pushes it to 100kph in 6.8 seconds which will be a welcome increase on the base model power I'm sure. I'm not sure if this model is coming to Australia, but I also don't know if there would be a market for it here between the base BRZ and the STi (if it comes here.) What do you think?
Read more about the BRZ on Autoblog.
Next is the Forester tS.
I reckon this car looks awesome and the first thing that grabs me is the claim that it'll do 0-100 in 6.2 and only has 250HP! That seems pretty good for a big car! (3,620lbs / 1642kg)
The Forester definitely looks more 'Mum and Dad' than the BRZ which is to be expected. Besides a little more poke and better styling is there enough to warrant choosing one of these over a standard one? I can't answer that, especially considering we have no pricing.
Check the Forester tS on Autoblog.
Opinions?
  • Like 1
https://www.sau.com.au/forums/topic/455519-subaru-ts-models-brz-forester/
as a devout follower of subaru.
never been one for the brz. handles okay, has no power, and the styling reminds me of a nerdy kid who got bullied at school thats been hitting the gym to look "hard"
its still a skinny weak thing underneath. no amount of sti badges can make up for a turbo.
the foz. needs some flared arches like the older models. but would def stick my wife in one.
  • Like 2
i have a 4 gt sedan. for the wife. cannot believe the size difference of the 5. its huge!!!!!!!!
Since when did you paint yours black and changed the plates?!
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
