The guys at Autoblog have recently added a few posts on both the Subaru BZR tS and the Forester tS.
From what I understand, the tS models will sit below the STi models (even though both of these cars are branded with STi badges.)
The BRZ first;
These calipers look fantastic although the overall disc size seems a little underwhelming.
The seats are Recaro's with STi branding.
Only the second tS badge I can see in the pictures.
The BRZ looks awesome with the black wheels and wing, theres more STi badges than you could poke a stick at. It has 200HP which pushes it to 100kph in 6.8 seconds which will be a welcome increase on the base model power I'm sure. I'm not sure if this model is coming to Australia, but I also don't know if there would be a market for it here between the base BRZ and the STi (if it comes here.) What do you think?
Read more about the BRZ on Autoblog.
Next is the Forester tS.
I reckon this car looks awesome and the first thing that grabs me is the claim that it'll do 0-100 in 6.2 and only has 250HP! That seems pretty good for a big car! (3,620lbs / 1642kg)
The Forester definitely looks more 'Mum and Dad' than the BRZ which is to be expected. Besides a little more poke and better styling is there enough to warrant choosing one of these over a standard one? I can't answer that, especially considering we have no pricing.
Check the Forester tS on Autoblog.
Opinions?
  • Like 1
https://www.sau.com.au/forums/topic/455519-subaru-ts-models-brz-forester/
as a devout follower of subaru.
never been one for the brz. handles okay, has no power, and the styling reminds me of a nerdy kid who got bullied at school thats been hitting the gym to look "hard"
its still a skinny weak thing underneath. no amount of sti badges can make up for a turbo.
the foz. needs some flared arches like the older models. but would def stick my wife in one.
  • Like 2
i have a 4 gt sedan. for the wife. cannot believe the size difference of the 5. its huge!!!!!!!!
Since when did you paint yours black and changed the plates?!
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
    • I was chatting with an ex SAU person who is involved in chooning euros now. He was saying the factory cars like Audi VW etc have something like 2000 tables that the ECU uses for getting everything "just right". Compare that back to any aftermarket ECU, and you'd be hard pressed to surpass 50 lookup tables. Even the Ford Barra engine has a few hundred lookup tables to run it (and they're still working some tables out too!)
    • Grab a temp probe, and probe each exhaust inlet runner with it sitting idling. Each one should be pretty darn close to the same temp. If you've got some reading higher or lower than the others, it's likely either air flow isn't equal, or your injectors aren't equal to each other.   The other things to check, is from the wiring changes that were made, were any earth's or grounds moved/changed.   Lastly, for the strut brace issue. It's not perfect, but can you get away with slipping a washer or two under the strut brace to raise it, and it still clean the bonnet? If you can, work out the height you need, that the motor can't torque up into, and get a spacer made for each side.
