Due to the wonders of cheap LEDs from china, I set about changing a few blown dash lights, only to go ahead and replace about 35 bulbs in the dash, climate control, cigarette lighter and shift lever. The results are quite impressive, I just hope these chinese ones dont blow prematurely. These are white LEDs, which make the gauges appear blue, the yellow lights (such as 4WD, synchro, defrost etc) have a touch more green in the colour (a little strange looking I admit), the red lights appear more pink, while the green lights just appear more vibrant.
If I had to do them in future, I would probably use white for gauges and green lights, red for red lights, warm white for yellow lights.
Also don't use an LED in the low fuel warning light. The circuit always has current running through it and it will constantly light an LED.
https://www.sau.com.au/forums/topic/455523-show-us-your-pilot-seat-lightshow/
  • 9 months later...
Are all those just pop-out type LED's or did you have to re-solder some of them?
Most of mine on the gloria require soldering, which I dont mind doing. But the interior pieces are just such a pain in the arse to remove. afraid im gonna break some.
The lights in the dash cluster are all accessible from the back of the cluster (which obviously means removal of a few interior pieces...annoying I admit). There are T5 sockets on the back of the cluster which twist out and accept a T5 wedge bulb.
I have an aftermarket head unit with its own internal lighting, which I didn't change.
The climate control unit has a number of "neo wedge" bulbs. Normally they take tiny "grain of wheat" incandescent bulbs. I think they are 5mm. You can get LED replacement sets on ebay, however I found that they did not screw in, and so I had to retrofit the SMD LED and resistor into the existing plastic bulb holder. It would be important to use SMD LEDs in the screen area, as you want maximum light dispersion. A regular lensed led will point the light directly downwards, but they may work OK in the lights for the buttons.
The ashtray light takes a T5 wedge bulb, and takes a little effort to dismantle.
The shifter light takes a T10 wedge bulb, but it must be a short one otherwise it wont screw in. I ended up adding a resistor to dull the light, as it was too bright.
Pro level: lastly I replaced the blown "grain of wheat" bulbs in the auto transmission power/snow switch. That requires dismantling the switch itself and creatively shoehorning both an led and resistor in each bulb slot.
I do like that color in the dials; is that just bulb upgrade in a standard dash?
it is not simple LED bulb upgrade. i can't figure out how does it work, but there is LED control unit box out side the cluster. also there is a switch to control the LED brightness.
Some additional control of the led lights would be ideal in most cases, for brightness etc. If I had some spare time and money I would probably use an arduino to take care of the speedo, tacho fuel and temp gauge. I had to rebuild my tachometer circuitry, but it can't be correctly calibrated without some additional mapping, which the arduino could provide.
attachicon.gif24198c.jpg&&0){for(var>
This makes sense now; it's also a complete overlay of the dash face as well.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
