Signwriter required at Penrith to do a 1m x 3m sign for me. Payment will be immediate after the job is done. With thanks Tez.
Hi Terry, aleks (FishingFreak in the stagea section) has a sign writing company based in St marys. He will look after you. Edited by Brick
https://www.sau.com.au/forums/topic/455541-temp-job-thread/#findComment-7514148
Good stuff Terry, we found him very reasonable, and gave good advice which saved us a decent bit of cash when we bought our gas hot water service.
He also came out on really short notice to unblock a drain, and didn't hit us with a callout charge because we'd used him before.
I'll always recommend guys like that.
  • Like 1
https://www.sau.com.au/forums/topic/455541-temp-job-thread/#findComment-7522371
  • 1 month later...
FishingFreak aka Aleks did a great Signwriting job for me thanks.
"Graphics and Print" - Recommended.
Next paying job is for a S/S weld of a Nismo muffler to the pipe.
Up to it Dale?
It pains me to say this but the muffler coming off is near new too!
HKS Silent Power one.
https://www.sau.com.au/forums/topic/455541-temp-job-thread/#findComment-7551754
Up to it Dale?
I only just saw this!
Let me know when you have some time Terry; I'm happy to have a look. I can purge as well for a neat internal surface.
  • Like 1
https://www.sau.com.au/forums/topic/455541-temp-job-thread/#findComment-7553515
  • 1 month later...
  • 10 months later...
Tomorrow free?
Would anyone have a free day 6am to 8pm tomorrow to help me check a car and (all going well), tow it back (on a UHaul trailer) to Blacktown?
Payment can be discussed on PM. Ta. Grateful.
I'm not available tomorrow, but happy to help on Friday if that works at all Terry?
https://www.sau.com.au/forums/topic/455541-temp-job-thread/#findComment-7744940
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
