Signwriter required at Penrith to do a 1m x 3m sign for me. Payment will be immediate after the job is done. With thanks Tez.
Hi Terry, aleks (FishingFreak in the stagea section) has a sign writing company based in St marys. He will look after you. Edited by Brick
https://www.sau.com.au/forums/topic/455541-temp-job-thread/#findComment-7514148
Good stuff Terry, we found him very reasonable, and gave good advice which saved us a decent bit of cash when we bought our gas hot water service.
He also came out on really short notice to unblock a drain, and didn't hit us with a callout charge because we'd used him before.
I'll always recommend guys like that.
  • Like 1
https://www.sau.com.au/forums/topic/455541-temp-job-thread/#findComment-7522371
  • 1 month later...
FishingFreak aka Aleks did a great Signwriting job for me thanks.
"Graphics and Print" - Recommended.
Next paying job is for a S/S weld of a Nismo muffler to the pipe.
Up to it Dale?
It pains me to say this but the muffler coming off is near new too!
HKS Silent Power one.
https://www.sau.com.au/forums/topic/455541-temp-job-thread/#findComment-7551754
Up to it Dale?
I only just saw this!
Let me know when you have some time Terry; I'm happy to have a look. I can purge as well for a neat internal surface.
  • Like 1
https://www.sau.com.au/forums/topic/455541-temp-job-thread/#findComment-7553515
  • 1 month later...
  • 10 months later...
Tomorrow free?
Would anyone have a free day 6am to 8pm tomorrow to help me check a car and (all going well), tow it back (on a UHaul trailer) to Blacktown?
Payment can be discussed on PM. Ta. Grateful.
I'm not available tomorrow, but happy to help on Friday if that works at all Terry?
https://www.sau.com.au/forums/topic/455541-temp-job-thread/#findComment-7744940
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
