Signwriter required at Penrith to do a 1m x 3m sign for me. Payment will be immediate after the job is done. With thanks Tez.
Hi Terry, aleks (FishingFreak in the stagea section) has a sign writing company based in St marys. He will look after you. Edited by Brick
https://www.sau.com.au/forums/topic/455541-temp-job-thread/#findComment-7514148
Good stuff Terry, we found him very reasonable, and gave good advice which saved us a decent bit of cash when we bought our gas hot water service.
He also came out on really short notice to unblock a drain, and didn't hit us with a callout charge because we'd used him before.
I'll always recommend guys like that.
  • Like 1
https://www.sau.com.au/forums/topic/455541-temp-job-thread/#findComment-7522371
  • 1 month later...
FishingFreak aka Aleks did a great Signwriting job for me thanks.
"Graphics and Print" - Recommended.
Next paying job is for a S/S weld of a Nismo muffler to the pipe.
Up to it Dale?
It pains me to say this but the muffler coming off is near new too!
HKS Silent Power one.
https://www.sau.com.au/forums/topic/455541-temp-job-thread/#findComment-7551754
Up to it Dale?
I only just saw this!
Let me know when you have some time Terry; I'm happy to have a look. I can purge as well for a neat internal surface.
  • Like 1
https://www.sau.com.au/forums/topic/455541-temp-job-thread/#findComment-7553515
  • 1 month later...
  • 10 months later...
Tomorrow free?
Would anyone have a free day 6am to 8pm tomorrow to help me check a car and (all going well), tow it back (on a UHaul trailer) to Blacktown?
Payment can be discussed on PM. Ta. Grateful.
I'm not available tomorrow, but happy to help on Friday if that works at all Terry?
https://www.sau.com.au/forums/topic/455541-temp-job-thread/#findComment-7744940
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
