Hey guys, update time again :yes:
So today I bought the last piece's of the puzzle that I need for my head rebuild
The Black Pearl will hopefully be done this weekend! That is if we don't run into an issues and if my Water Pump arrives :dry: I ordered it last week and still have not received it :down:
So in this update we have:
- Exhaust Manifold Studs w Washers and Brass Nuts to hold em in place
_________________________________________________________________
- Timing Belt Oil Seal Kit + Timing Belt Tensioner's
- Permaseal Turbo Gasket Kit
- 10l of Penrite Radiator Coolant
- Penrite 10w40 10|Tenths Racing Oil + Filter
I'm officially ready for this weekend! I hope my Water Pump arrives tomorrow or Friday :(
Either way I will let you guys know what happens!
Until then :action-smiley-069:
  • Like 1
Hello loyal readers! :action-smiley-069:
So, AWESOME news, my Water Pump arrived this morning! Courtesy of Kudos Motorsports
_________________________________________________________________________
This weekend will go ahead!
I am dedicating Saturday and Sunday to this job, so hopefully come Sunday The Black Pearl will finally be running again :yes:
Starting @ 9am Saturday, on my team I have a qualified mechanic and a good mate who has recently just done this exact same job with his dad (Also a qualified mechanic), So I know this job is in good hands :D
I will be taking footage via Go Pro and will upload these right here for you :thumbsup:
Until then!
:thanks: for reading this far
  • Like 2
  • 3 months later...
I bet you guys never thought you'd hear from me again :thumbsup:
However, as I've said somewhere on this thread, you can't get rid of me that easy :no:
So, a lot has happened but at the same time, not much has happened. So, we did complete the head-swap, HOWEVER, little did I know, this was the start of a nightmare for me :unhappy:
So... Head swap was done but when the car had it's first start it was making a very bad noise. I feared the worst (Bottom end damage), however luckily it wasn't.
For weeks, we were trying to figure out what this noise was. We checked timing, all sensors, everything! But to no avail
So, I ended up towing my car to PZP. $987 later and we found out the reason for this is because the lifters had not been bled properly
I got the car back from PZP last week, however there is still the slightest lifter noise occurring. PZP had advised me the car needed to be driven for 2 weeks to try and get oil up into the lifters and then the sound should go away.
So, I did just that! I took it for a nice drive on Saturday :D However, this noise got louder :/
So, I think I am going to take the car back to PZP on Saturday to advise them of this. When I got the car back, PZP advised if the noise does not go away, the next step is taking the head off..
At this point I'm thinking an engine swap will be a cheaper option than what re-taking the head off will cost :geek:
But at the same time, I don't want to buy another engine and then have more issues, so I'm stuck between a rock and a hard place :unsure:
Opinions would be great!
Until next update :miner:
- J
So how bad is the noise now. If it's not that bad u could probably just put up with it. You could also try different oils thicker or thinner depending on what's in it now and see if it changes at all. Hard to say without being there to hear it properly. I used to have an sr20 with lifter tick. I still thrashed its guts out for 2-3 years without issue.
I dont know where $987 comes from cause wouldnt they just have to put a feeler guage under the cam lobes to see that the lifters arn't pumped up? must be $900/hr at that place..
They may have cleaned things a little too well at the engine shop, cause the lifters and the lifter bore rely on tight clearances which on older engines help to cover up with carbon, this why its not good to clean old engines i reckon..
You could try removing the lifters and see for yourself if they can pump up, I changed some LS1 lifters not long ago, they were brand new and hard as, but when put in car they were good till things got hot then sounded terrible so most likely the bore was worn cause its alluminium, this is a possibility...
Edited by AngryRB
  • 1 month later...
Hey Angry, I ended up removing the Lifters and then manually bleeding my original Lifters to install, it worked but then this happened -_- (see below update)
Update time:
Put Lifter-Free in The Black Pearl to try and get rid of the terrible Lifter sound, took it for a quick drive to the servo afterwards. All went well and the ticking went away! Yaaaay! Or so I thought -_-
Since the noise went away, I went for a drive to stretch the cars legs finally. Got 10 minutes down the road and saw some steam coming from my bonnet.
Pulled over immediately and saw coolant had gone everywhere ? if you look at the picture, you can see the cause of this is my Water Pump pretty much snapping...
So, now need to get a new Water Pump and off to HyperDrive she goes to get fixed. I hope this is the last time...
Edited by MC-WOSHY
  • 3 weeks later...
Wow. That sucks. How tight was the belt?
Pretty tight for that to occur haha. I didn't do it, my mate did. Didn't blame him though as I knew the risks etc before getting the work done
Who tightened the belt? thats a pretty easy DIY job..
Same as above :P
Hey just read through this whole thread, awesome work bud, I guess we all get a bit of bad luck sometimes but keep at it.
should have my own series 1 r33 within the next couple of weeks, so just doing research now.
Cheers man, glad you like the build so far! Lot of work and money has gone into this car :D And a lot more to come (read my update below). Awesome! going to make a build thread too??
Hmm lifter tick and a broken water pump, its fun to learn but cheaper sometimes to get a good workshop to do the work...
Yep, totally agree! Prior to this I did all the work via HyperDrive, this was the first time I tried myself. Let me tell you know, that's never happening again! Going back to letting professional's do the work :)
Ok guys,
Sorry about the lack of updates on the update front. Had some bills come up, recently sold my Pulsar and just brought a GQ Patrol (Gee I love Nissan's), which needed a few things.
Never fear though, the Skyline has/will never miss out on the love!
Genuine Water Pump take 2:
Car goes into HyperDrive next week to have the new Water Pump fitted :D They are also checking the engine out to make sure everything is fine. Hopefully and I mean HOPEFULLY this all goes well. I would love nothing more than being able to drive the darn thing for more than 10 minute's! In the last 6 months I've driven it twice, which is a lot less for my liking. So I'm hoping next week I can start hitting consistent boooooost :banana:
Providing all goes well with this, The Black Pearl will be getting some love as a reward ;)
- Z32 AFM
- GReddy PRofec OLED
- 950cc DeatschWerks Injectors
- 6Boost Manifold (Low-Mount)
- Garrett GTX3076R w .82 Rear Housing
- HyperDrive Tune
Can't wait for that, will take me a couple of months to save up as I'm paying for it all up front.. But waiting and slowly accumulating the parts is half the fun right? :yes:
More on that after next week though, need to make sure The Black Pearl pulls through this Water Pump installation without any further issues
Until then guys, thanks for reading! :action-smiley-069:
After driving a GQ patrol, the skyline will feel like a 10second car lol... mine has become a museum piece for the last year :yes:
Yep... you are dead right Mark! Now just need to make it 10secs ;)
That's no good, what's being done to her!?
Bit dusty, but..... SHE'S BACK! :bunny:
Running healthy now, so that only means one thing... UPGRADES! :w00t:
Keep an eye on this space :yes:
Would like to give a shout-out to HyperDrive in WA, they did an awesome job for a fair price, couldn't recommend more! :D
  • Like 1
she's got a dirty 30 with neo head in her, lol... need pipes fabricated and then tuned and she'll be proper angry :mrt:
look forward to your future upgrades, good looking R33. :thumbsup:
Ooooh, I like! Similar to what I want to do, but I'm torn between doing it for the 33 or my dream car (34R).
Cheers mate, really good to see people have been giving the thread a following (like yourself), you've still been following from the early days! :worship:
Thanks mate, appreciate the kind words! Not done on the look of it yet, still little bit's to take care of.. eg:
- Coilovers (STD Coilover's is what I'm getting)
- Enkei RPF1 (In Blaaaaack) - 18X9.5 +15
- Whiteline Sway-Bars (Front & Rear)
- Front & Rear Strut Bar
At that point I'll be happy with the outside, will just be little thing's to tidy up like seals etc
But that's all part of the journey! :cool:
Edited by MC-WOSHY
    • Tried them, they leaked. I also foolishly bought some random rubber ones that leaked too.  Genuine and not looked back.    As always though sample size of one, and I could have made a mistake installing them.
    • Technically still manual process to set it first time though
    • Shit job but not hard. I'd use a piece of wood to knock the plastic lid open to avoid damaging it, use a vacuum to clean up the fuel sender lid also so crap doesn't fall in. I'd probably do pump and filter at the same time since you're already in there, I reused my OEM sock after a quick clean since the one provided wasn't long enough. Could also hardwire your pump if you feel inclined.
    • Supercheap auto sell this: https://www.supercheapauto.com.au/p/pat-plusquip-fuel-tank-lock-ring-tool---universal-kit/SPO3564082.html I own this and if you HAVE PATIENCE you can remove it without snapping lines and generally being incredibly angry, then said at doing this job. Sadly I've removed the pump about 75,000 times over the years. I don't know if you're a large lad or a smaller lad but my advice to you as someone who is 185cm is if you are my height or smaller, is to sit in the boot and take your time. Yes you can put the seal on. The seal goes over the white thing/lid (you will see how it 'slots' in) then the whole assembly presses into the tank. then you screw the lock ring on. I spent so much time doing things the wrong way by trying to mount the seal into the tank first, then putting the white fuel hat on in the space provided. Put it together first then it'll all go in. But seriously be careful about removing the hoses AND where the removal tool is moving relative to the plastic pipes coming out of the lid when you've removed it. IT IS BRITTLE So brittle in fact I have two spare lids, and would recommend buying a spare and having it handy before attempting to do this. May as well throw https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD in the tank as well, as this uses all stock plugs and such. You may need to/strongly recommend you re-use your OEM fuel sock or use the one supplied with a length of hose so it sits at the stock height.
    • The tension is automatic....if you follow the installation instructions Self adjusting tensioners are used when the chain/belt is expected to stretch during it's service life, but the downside is the tensioner itself can fail and cause a problem, while the RB system is locked once it is installed and doesn't have that risk
