1998 low kms skyline in top condition inside and out. This car is faultless, interior looks brand new. It has just been over the pits and comes with permits for mods and 6 months rego.
Mods inc;
3" Kakimoto stainless steel catback exhaust
(Imported from Japan worth $2200+)
18" Zumbo wheels with new 265 low profile tyres
New Bluetooth media player with new 6" fusion splits run off Sony amp-recieve and make calls, plays music off iPhone etc
Matt black vinyl on bonnet, boot and side decals
Front mount inter cooler
Turbo smart BOV
R34 GTR Turbo
R34 Fuel rail with plenum
Greedy boost controller, 10psi normal, low setting 12psi, high setting 14psi
Tomei fuel pressure regulator
Just had service inc oil change and filter
New spark plugs
New high performance coil packs
New battery
Pod filter
BES turbo timer
Oil cooler with top mount oil filter
Beilstein struts and lowered springs all round
Auto watch car alarm
Air con works perfect
Only genuine enquiries, no joy riders or scammers , if you can't see this car in person please don't bother me. Please no low ball offers, this car has been well looked after and loved not thrashed
Comes with original complete exhaust, original air intake box and various other parts taken off car
# r32 r34 s13 s14 s15 180sx silvia skyline turbo drift rb ca sr supra
Located Applecross , Western Australia post-139711-14286465222045_thumb.jpgpost-139711-14286465395774_thumb.jpgpost-139711-14286465548068_thumb.jpgpost-139711-14286465698555_thumb.jpg
https://www.sau.com.au/forums/topic/455583-r34-gtt-skyline/
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
