@Leroy Peterson, can you give us some more info? Where did you find this? it looks to be in amazing condition.
Are you into English cars or did this just peak your interest this time? I'd love to hear the background to this.
19 hours ago, Steve85 said:
Leroy! My god! That's gonna hurt... I hope you are good with electrics! did you get a warranty? (jk).
I bet he's shopping for that warranty before attempting to do anything to it :P
  • Like 1
I've decided to keep track of the build here: http://www.zeitakuvip.com/forum/member-s-rides/non-vip-builds/22023-triumph-tr7
After the whole Photobucket fiasco, i dont really want to be posting on multiple forums again... except some odd updates on the pulsar on SAU. All the detail is on PGA.
Everyone carrying on about rust has me real worried about the car. like how do you wash a car that rusts easily? cant use water lol. It also will be sitting outside for a week or two which has me concerned... ill buy a cover for it I think
  • Like 1
11 hours ago, Leroy Peterson said:
Thanks for putting that link up. I'll be lurking in the background (like always!).
3 hours ago, Leroy Peterson said:
Yeah dolomite sprint. Think it needs a lot of work. Might have been a parts car.
Doesn't look too rusty on the surface.
Once you dig deeper...
I'm tempted to look at it haha
On 12/08/2017 at 3:41 PM, Count Grantleyish said:
Whoa, I'm seeing double!
Haha, one is silver, one is white. Also one is knackered (gearbox issues) and one is in mint condition...
  • Like 1
2 minutes ago, Count Grantleyish said:
Gearbox issues, is it under warranty?
Silver one is knackered. It has just become my daily, i've had it for two years and it has served me well so far. It's certainly not under any kind of warranty.
The gearbox had a it of a meltdown about 3 or 4 months ago and was flaring and carrying on. I ignored it (like you do) and then finally at the service mentioned it was "a bit rough". They recommended a new gearbox for 10k. I declined and we looked at the new models, but none of them were my thing. In the end, we came back to the same model, only this one has been well kept, well serviced and has every conceivable option these things came with.
If the gearbox does go, it will be a project for my friends and I to change it over and see if we can reprogram the car. Surprisingly it has been very well behaved since the initial problems, but i'm pretty much expecting it to stop moving the back wheels at any stage now. When it does, bring on the spanners... :)
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
