  • 1 month later...
On 7/4/2020 at 3:15 PM, niZmO_Man said:
I like how the "hook" bits on the BMW lights is inverted and less prominent compared to the Subaru.
Yes I know the photos are bad, my camera phone is stuffed after Android 10 update
Nice ride! I always like the BMW wheels.
  • 10 months later...
12 minutes ago, PranK said:
That looks awesome. I bet its a hoot to drive!
Yes it is, does everything without fuss. The amount of grip available is hard to believe for a wrong wheel drive car, definitely a step up from the Mini but needs some love which I'm happy to give it.
The Mini was great but eventually all good things come to an end. Im sure the new owner will love it, they're getting a damn good car.
  • Like 1
Thank f**k finally someone bought a MK3 megane
Best car for the money bar none, road, track, everything in between. My 225 was lovely. The 250/265/275 have a ton of aftermarket support if you want to go that way too.
  • Like 1
They are a hoot to drive, still have fond memories of the Hertz rental 275 on the Old Pacific Highway
Ridiculous cornering ability, hard ride, enough straight line speed and a whole heap of fun
I would have bought one if it wasn't for my narrow driveway
Just going to leave it for now, it has the mid resonator deleted otherwise standard. Its a 265 cup+ so it has an extra 15 lamas
5 hours ago, niZmO_Man said:
How's MINI vs. Megane in everyday driving? Interior/build quality?
Surprisingly the mini build quality was very good. 247k km, drove beautiful, no rattles from the interior. Solid little car. Shit at putting the power down, no lsd.
The megay is a real nice place to be, being a cup+ it's the more luxurious comfy version. It has high kms also at 195. There are some interior rattles that are affecting my ocd. It drives awesome and is mechanically solid. Drive wise, it's in a different league to the Mini. It's apples and oranges.
I just sold the Mini to the first viewer, ex bmw tech. He agreed with me that it was the best condition 247k car he'd ever seen.
1 hour ago, Dose Pipe Sutututu said:
Nissan in disguise, you are a true JDM enthusiast
Busted, lol.
Faux Nissan, gohsn style.
  • Like 1
  • Haha 1
I remember seeing one at Phillip island a few years back, stock as a rock fitted with Bridgestone semis re55 i think. Ran 1:54's, my 33 with double the power and the extensive mods has run a best of 1:50.4.
54's with tyres is impressive
  • Like 1
Not to mention PI is a bit of a power track...
But yes they can be tuned and have all sorts of mods available given they exist in a racing series for them. The MK3 had a few rattles, one of which is the brake pedal which makes all sorts of racket. It can be fixed with a ziptie.
Proper JDM.
  • Haha 1
Does this count as Euro? My new daily, it’s got a Renault motor! Lol
Just fitted a Pro Vent catch can and Plazmaman, cooler and pipe kit as well as Plazmaman intake pipe. Next is turbo back exhaust, then off to Jez for a remap. 👍🏼
Proper JDM.
Details on zip tie fix. I need max jdmness in my life
You'll know if you hear it, same problem on MK2 RS Megane as the MK3. If you hear a really noticable, loud rattle, that goes away if you put 1% of brake pressure on your pedal while driving along - Bust out the zipties to take the slack out of the pedal.
You dont need to engage the pedal or anything like that, it's very obvious when you look at it.
Side note: I found the Megane REALLY easy to work on. May be a little weird when you first look at it, but as soon as you do I found it really, really nicely and obviously laid out in pretty much every system.
  • Like 1
Bust out the WD40! For me providing TLC to mine was a case of
"Oh no, whats that [problem]"
take cursory glance
"Oh, that's pretty straightforward"
The trickiest OEM cars are nothing when you modify a Nissan lol.
    • From there it is trickier. Ecutek seems to be one of those closed ecosystems where everyone password protects their tunes which means I either choose a tuner and can't change from them and can't make any changes myself for any reason, or I have to buy the tuning software (about $4k) and then get someone to tune from scratch (which is not simple with all the multi dimensional tables these days). Once you buy about 300 "flash points" per ECU you can get it tuned and add their "RaceROM" function which hacks extra functionality like launch control onto the ECU, and also makes extra data available for logging over CAN Not sure what I'll do there yet; I'm tempted to use one of the overseas shops that does billions of remote tunes of the platform instead of starting from scratch locally, a lot can be done online these days.
    • Can I log IAT eh? Well, can now So next thing was looking at data logging. Not straight forward because none of the motorsport displays have cracked the nissan/inifinti CAN and ECU based displays don't do g logging, lap timing, predictive laps etc.  So, I bought an Ecutek dongle from Tunehouse (Oz distributor). Even without a tune onboard that allows display and logging of about 50 parameters via Android (and presumably iOS) app. Approx 600 for the bluetooth + Usb version That gives me (pretty ugly but) functional dash display on Android And logging of these parameters I'll play around a bit over the break, but at least now I can make sure I have oil pressure when I get to some track testing.
    • I don't know what globes/headlight connector they run, but I'd be looking for a female adapter to plug into the existing headlight on one side. Something like this https://www.ebay.com.au/itm/256017245989 Then I'd use a pair of single input, double output relays (one for low, one for high), mount them in a spare space in the fuse box if you want to to look more original (and be easier to maintain). Then 2 new power sources from the main stud in the fuse box via a fuse to each relay. Low from the headlight adapter pin triggers low relay and high from the high headlight adapter pin triggers high and low. Earth the relays and new headlight sockets and off you go. Because it triggers off the original headlight all of the dipping/hi on/high flash all still works
    • I reached 10 posts and wanted to make my build thread too but still can't add pictures to posts so I have no idea how it works 😂
