  • 1 month later...
On 7/4/2020 at 3:15 PM, niZmO_Man said:
I like how the "hook" bits on the BMW lights is inverted and less prominent compared to the Subaru.
Yes I know the photos are bad, my camera phone is stuffed after Android 10 update
Nice ride! I always like the BMW wheels.
  • 10 months later...
12 minutes ago, PranK said:
That looks awesome. I bet its a hoot to drive!
Yes it is, does everything without fuss. The amount of grip available is hard to believe for a wrong wheel drive car, definitely a step up from the Mini but needs some love which I'm happy to give it.
The Mini was great but eventually all good things come to an end. Im sure the new owner will love it, they're getting a damn good car.
  • Like 1
Thank f**k finally someone bought a MK3 megane
Best car for the money bar none, road, track, everything in between. My 225 was lovely. The 250/265/275 have a ton of aftermarket support if you want to go that way too.
  • Like 1
They are a hoot to drive, still have fond memories of the Hertz rental 275 on the Old Pacific Highway
Ridiculous cornering ability, hard ride, enough straight line speed and a whole heap of fun
I would have bought one if it wasn't for my narrow driveway
Just going to leave it for now, it has the mid resonator deleted otherwise standard. Its a 265 cup+ so it has an extra 15 lamas
5 hours ago, niZmO_Man said:
How's MINI vs. Megane in everyday driving? Interior/build quality?
Surprisingly the mini build quality was very good. 247k km, drove beautiful, no rattles from the interior. Solid little car. Shit at putting the power down, no lsd.
The megay is a real nice place to be, being a cup+ it's the more luxurious comfy version. It has high kms also at 195. There are some interior rattles that are affecting my ocd. It drives awesome and is mechanically solid. Drive wise, it's in a different league to the Mini. It's apples and oranges.
I just sold the Mini to the first viewer, ex bmw tech. He agreed with me that it was the best condition 247k car he'd ever seen.
1 hour ago, Dose Pipe Sutututu said:
Nissan in disguise, you are a true JDM enthusiast
Busted, lol.
Faux Nissan, gohsn style.
  • Like 1
  • Haha 1
I remember seeing one at Phillip island a few years back, stock as a rock fitted with Bridgestone semis re55 i think. Ran 1:54's, my 33 with double the power and the extensive mods has run a best of 1:50.4.
54's with tyres is impressive
  • Like 1
Not to mention PI is a bit of a power track...
But yes they can be tuned and have all sorts of mods available given they exist in a racing series for them. The MK3 had a few rattles, one of which is the brake pedal which makes all sorts of racket. It can be fixed with a ziptie.
Proper JDM.
  • Haha 1
Does this count as Euro? My new daily, it’s got a Renault motor! Lol
Just fitted a Pro Vent catch can and Plazmaman, cooler and pipe kit as well as Plazmaman intake pipe. Next is turbo back exhaust, then off to Jez for a remap. 👍🏼
Proper JDM.
Details on zip tie fix. I need max jdmness in my life
You'll know if you hear it, same problem on MK2 RS Megane as the MK3. If you hear a really noticable, loud rattle, that goes away if you put 1% of brake pressure on your pedal while driving along - Bust out the zipties to take the slack out of the pedal.
You dont need to engage the pedal or anything like that, it's very obvious when you look at it.
Side note: I found the Megane REALLY easy to work on. May be a little weird when you first look at it, but as soon as you do I found it really, really nicely and obviously laid out in pretty much every system.
  • Like 1
Bust out the WD40! For me providing TLC to mine was a case of
"Oh no, whats that [problem]"
take cursory glance
"Oh, that's pretty straightforward"
The trickiest OEM cars are nothing when you modify a Nissan lol.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
