They look insane.
$55k drive away is a bargain too. Got two years to run on my current lease. The RS will be a strong contender for a replacement then.
Can't wait for Chris Harris to test it.
  • Like 1
But do these things have Ford's dual clutch transmission?
So many complaints from everyday drivers.
Not such a problem if the car is pushed hard where the transmission can correctly predict the next gear.
St is manual only. And FYI the dual clutch transmission problems in the normal focus have now been solved. The issue was an incorrectly fitted transmission seal leaking onto the clutches causing excessive shudder and slipping. Ford has been replacing the contaminated clutches and seals as required. They know behave quite well. Still have very little occasional low speed shudder but acceptable. My wife owns a focus and we have gone through the above. We're now quite happy.
Good news that Ford has finally acknowledged there was a problem, took long enough.
Many dissatisfied owners will never trust that company again, but then it's pretty much the same story from the rest too.
What amazes me is these car companies jumping onto the twin clutch band wagon when some can't even get a single working properly.
You'd think after 100 years that the old dry plate clutch would be trouble free.
Yeah, it was a quiet acknowledgement. Handing clutch control to a computer system sounds good in theory but hey, so did communism lol. Mass producing manufacturers hold out on admitting a fault or problem for as long as they can for reasons I don't understand. The only thing that makes any sense in that case is if they don't know what the actual problem is.
Back on topic. The st is manual only and is a cracker of a car. The coming RS can only be better, you would think. AWD and a drift mode button. Hmmm, much want. If only the wife could /would drive a manual.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
