Do u have an aftermarket alarm ? who fitted it, do u have ignition lights, I had the same problem it was the idiot who installed the alarm had no idea how to.
Yes, there's a aftermarket alarm installed recently. Ignition light u referring to, is it the keyhole? how did u solve ur problem?
My situation is, last week battery gone flat. unplugged the +- and recharged it with a charger.
everything works fine as usual until on the same day i drove it to office n left it for few hours. after that i tried to start it, it can be cranked but unable to start. the throttle % isn't giving any respond on the screen when stepped on it.
and the immobilizer RED LED was ON. No solution and called for carrier and car being carried back home. After 2 days, it back to normal again. Then next day, it gone back to the same problem.
http://www.sau.com.au/forums/topic/455132-alarm-install-warning/
Ignition lights are the lights that come on when u turn the key on, and go off when it starts.I had to have the alarm installed a second time but by someone who knew what they were doing.
My ignition light isn't working, seems the alarm installer fked it up i guess? Btw, Thanks a lot for the info. anyway, my gtr mechanic told me to send it back to his workshop and he'll sort it out for me and not back to the installer instead.
  • Like 1
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
