I have had coolant poor down from behind the engine somewhere and passing down onto the ground generally when the car gets to temperature. . Rather than replace heater hoses which i think is the issue. I want to delete the heater all together. Is it a big job?
Just join the two pipes going through the firewall into the heater core on the engine side. Pull of a hose and get something like a brass plumbing pipe from bunnings that matches perfectly and cut to size and clamp the two hoses that would otherwise run into the heater core together. Will solve your leaking issue if your heater core is in fact the problem. Getting the heater core out of the Dash is a much bigger job from the inside.
Edited by sonicz
I just want to delete the heater hoping that is the problem.. what else could it be? Btw I have checked inside the car drivers side and passenger no signs of coolant leaking inside.
Edited by boobeedoobee
If it's not leaking inside then the leak is in the engine bay somewhere. Try as sonic and Ben have already stated and if it's still leaking you will have to find the leak. No other way around it.
Generic 1m lengths of oil and water hose isn't expensive, and by the sounds of it they will need replacing regardless.
If it is leaking behind the engine then you really have NO CHOICE but to find the hose back there that has a hole in it and replace it. And of course, because all the other hoses back there are old and crusty, you should do them too.
Deleting the heater would be a counterproductive effort that would take the same amount of effort as just fixing the problem.
  • Like 1
by the sounds of it you have a leaking hose which may or may not be a heater hose, I suggest finding which hose it is and replacing it.
If it was the heater core that was leaking the water would be inside the cabin
Ok thanks ill replace the leaking hose which your right might night be a heater hose. Just wondering though before I go and buy a heater hose kit..as I will be deleting the heater will this eliminate the need to replace the heater hoses?
Ben is there a way if getting around that after deleting the heater?
There are options, electric heater fan things for that very reason. I don't think j they actually work particularly well, but they satisfy the law.
I feel like in the time you've spent asking for ways aroung the way around, you could have just organised parts to fix the problem
I changed all my heater hoses with a Greddy copy plenum a few weeks back. Was a pain in the ass, but only took about 2 hours to replace all 4 heater hoses. Stop being lazy and fix the car rather than putting everything in the too hard basket.
Ok thanks heater delete it is.. save future leakage problems. Less hoses less trouble. I've never actually used the heater and never will. Wasn't trying to be lasy. Just needed to know what parts to organise depending on which way i went with it. Air con will go also
Google heater hose diagram rb26 and then decide on what you would like to do. Whether that may be replacing all hoses (I would do this) or cutting and blocking the heater hoses. It's one of the first things kids learn while driving around in beaters. Heat and plastic doesn't mix well after 10+ years.
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
