I have had coolant poor down from behind the engine somewhere and passing down onto the ground generally when the car gets to temperature. . Rather than replace heater hoses which i think is the issue. I want to delete the heater all together. Is it a big job?
Just join the two pipes going through the firewall into the heater core on the engine side. Pull of a hose and get something like a brass plumbing pipe from bunnings that matches perfectly and cut to size and clamp the two hoses that would otherwise run into the heater core together. Will solve your leaking issue if your heater core is in fact the problem. Getting the heater core out of the Dash is a much bigger job from the inside.
Edited by sonicz
I just want to delete the heater hoping that is the problem.. what else could it be? Btw I have checked inside the car drivers side and passenger no signs of coolant leaking inside.
Edited by boobeedoobee
If it's not leaking inside then the leak is in the engine bay somewhere. Try as sonic and Ben have already stated and if it's still leaking you will have to find the leak. No other way around it.
Generic 1m lengths of oil and water hose isn't expensive, and by the sounds of it they will need replacing regardless.
If it is leaking behind the engine then you really have NO CHOICE but to find the hose back there that has a hole in it and replace it. And of course, because all the other hoses back there are old and crusty, you should do them too.
Deleting the heater would be a counterproductive effort that would take the same amount of effort as just fixing the problem.
  • Like 1
by the sounds of it you have a leaking hose which may or may not be a heater hose, I suggest finding which hose it is and replacing it.
If it was the heater core that was leaking the water would be inside the cabin
Ok thanks ill replace the leaking hose which your right might night be a heater hose. Just wondering though before I go and buy a heater hose kit..as I will be deleting the heater will this eliminate the need to replace the heater hoses?
Ben is there a way if getting around that after deleting the heater?
There are options, electric heater fan things for that very reason. I don't think j they actually work particularly well, but they satisfy the law.
I feel like in the time you've spent asking for ways aroung the way around, you could have just organised parts to fix the problem
I changed all my heater hoses with a Greddy copy plenum a few weeks back. Was a pain in the ass, but only took about 2 hours to replace all 4 heater hoses. Stop being lazy and fix the car rather than putting everything in the too hard basket.
Ok thanks heater delete it is.. save future leakage problems. Less hoses less trouble. I've never actually used the heater and never will. Wasn't trying to be lasy. Just needed to know what parts to organise depending on which way i went with it. Air con will go also
Google heater hose diagram rb26 and then decide on what you would like to do. Whether that may be replacing all hoses (I would do this) or cutting and blocking the heater hoses. It's one of the first things kids learn while driving around in beaters. Heat and plastic doesn't mix well after 10+ years.
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
